Thread: 1993 Driver Door Won't Open from outside, got it all apart, now I'm stuck, HELP!
Results 1 to 4 of 4
  1. #1 1993 Driver Door Won't Open from outside, got it all apart, now I'm stuck, HELP!
    Jan 2013
    Utah
    I'm working on a 1993 Grand Prix, sedan, standard looking pull up door handles where the drivers side won't open from the outside. I've got the whole thing apart, door handle off, I popped off the rod going to the door handle, adjusted the barrel up a couple turns. So far I've been doing all this by trial and error, but I believe I'm headed down the right path.
    Problem now is that I can't, for the life of me get the rod threaded back up through and attached down at the linkage in a position where it is in the correct position to accept the door handle. It seems like it should be straight forward, there can really only be two positions based on how it fits into the handle, but I'm striking out. I'm beginning to wonder if it's bent incorrectly. I can't bear the thought of having to take apart the other door to see how the rod should be positioned, but I can't find any diagrams or photos of the way this assembly should look.
    Thoughts on how I solve this problem?
  2. #2 Re: 1993 Driver Door Won't Open from outside, got it all apart, now I'm stuck, HELP!
    Jan 2013
    Utah
    Man, it's hard to believe nobody on this forum has had experience replacing a door handle on an older Grand Prix and adjusting the travel on the rod. I've found the thread on this topic but with the coupe where the door handle is up in the door frame close to the window, it appears to be a different animal. I've been able to get the rod back into the door handle, but I'm still not getting the travel necessary to activate the catch down in the latch mechanism itself.
    I could still really use some help...
  3. #3 Re: 1993 Driver Door Won't Open from outside, got it all apart, now I'm stuck, HELP!
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I can't offer much help but I had to do this on my sons 92 Regal..... several times. I'm not sure how to put it. I had to remove the handle from the two 10 mm bolts on the inside, put it in the top part of the handle and shove my hand in the door and line up the rod with the pin in it (with the plastic clip piece) and try to jam it into the hole on the door.
    You can try this.
    EBSCOhost - world's foremost premium research database service
    user name : student
    pass - watc
    Alldata. Should be able to find your car and possibly what the trick is to fix it.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  4. #4 Re: 1993 Driver Door Won't Open from outside, got it all apart, now I'm stuck, HELP!
    SE Level Member iamz3r0's Avatar
    Sep 2013
    Virginia Beach
    Sorry to revive an old thread but I just had the same issue on my 93 GP SE. Figured I'd share my solution.
    Remove the bolts holding the cover onto the handle mechanism. DO NOT lose these. Without the bolts securing the handle it can pull apart and break easily. When you get the cover off, you'll see the long threaded bar that push the latch.
    If your door isn't opening from the outside but opens from the inside, its usually an issue with where the pin is threaded on that bar.
    If you use something flat, you can remove the clip holding the pin that holds the handle to the mechanism.
    When you slide the clip forward, it'll free the pin on the bar. Just loosen it a bit so it pushes the bar for the latch further, then reassemble it. Make sure you put the pin through the clip before you slide it back onto the handle mechanism.
    Its actually very simple. I just recently replaced both of my lock cylinders in my door and my driver-side door handle assembly. It actually cracked from yanking on it when I had this issue.
  1. Outside Driver Door Latch For 1993 GrandPrix NEED HELP
    By KtwnINDY in forum Introductions/Noob Questions
    Last Post: 01-28-2013, 10:21 PM
  2. 1993 4 Door Grand Prix Inside Door Handle
    By buickapollo in forum General Tech Discussion
    Last Post: 01-17-2013, 11:45 AM
  3. No Start - - key was stuck - No Lights except for oil and door open
    By Eric Downing in forum Audio, Security & Visual Electronics
    Last Post: 09-15-2012, 01:19 PM
  4. 1993 grand prix coupe driver side door handle
    By joebobyoung in forum Introductions/Noob Questions
    Last Post: 12-24-2011, 10:58 AM
  5. Door Signal stuck open on DIC
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2011, 07:39 PM
