Thread: Upgraded to an A2A IC System.
Results 1 to 20 of 27
  1. #1 Re: Upgraded to an A2A IC System.
    SE Level Member TurboGTP's Avatar
    Cali
    Where did you get your Intercooler Piping & what Angles did you go with ?
    Show Me The Boost
  2. #2 Re: Upgraded to an A2A IC System.
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Quote Originally Posted by TurboGTP View Post
    Wow this thread is back from the dead. LOL
    Here is the info on the IC piping.
    I bought the piping from CXRacing.com.
    I emailed them and made a special order. The kits on ebay include pipes you don't need. I did have some piping left over but I rather have more then come up short
    Here is the piping I bought from them
    1 – J pipe
    3 – Straight pipes
    2 – 90º L pipe
    2 – 45º pipes
    2 – 45º hose couplers
    6 – straight hose couplers
    25 - T-bolt clamps (Some may vary in size if you have transition hoses)
    This does not include the transition hose couplers for the IC core, turbo and MAF. Sizes can vary depending on set up.
    2 - 3” to 2.5” (IC core)
    1 – 2” to 2.5” (Turbo)
    1 – 3.5” to 2.5” (MAF)
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  3. #3 Re: Upgraded to an A2A IC System.
    Cali
    What size piping did you go with 2.5 or 3.0 & is that piping holding up to the boost ?
    Show Me The Boost
  4. #4 Re: Upgraded to an A2A IC System.
    Cali
    Oh sorry for bringing it back from the died.. I searched & found this thread.
    Show Me The Boost
  5. #5 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    The piping is 2.5". Holds up with no problems
    I'm glad this came up again. This way guys can see what is used for a turbo setup.
  6. #6 Re: Upgraded to an A2A IC System.
    Cali
    Ok i think i might just get that instead of buying the Intercooler Kit from ZZP & save some money.
    Show Me The Boost
  7. #7 Re: Upgraded to an A2A IC System.
    Jan 1970
    Maquoketa, Iowa
    Be careful, I believe Sal uses the car mostly for drag, so he has his own reasons to delete the front bumper support. If you get a large enough front mount, you would most likely need to do this also. Its not totally unsafe, but it is another piece of metal protecting you from really messing up yourself or the car.
  8. #8 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    It will be cheaper to get all the piping and front mount on your own. You can get a smaller FM, model# TR10 (I think), that should fit behind the bumper support.
    I will be making a bar that will go across in front of my car soon. This way I am a little protected.
    I really only use my car on the weekend if I have a chance and at the track.
  1. ABS System?
    By mcg_999 in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2008, 10:40 AM
  2. ABS System
    By Bonvoi29 in forum General Tech Discussion
    Last Post: 06-04-2008, 01:17 AM
  3. new car = new system
    By ninjamonkey in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2008, 05:43 PM
  4. How to put in a Nav system
    By gp04 in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2008, 12:33 AM
  5. My system right now
    By Grandprixboy1224 in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2008, 05:04 PM
