Thread: Upgraded to an A2A IC System.
Results 1 to 20 of 27
  1. #1 Re: Upgraded to an A2A IC System.
    SE Level Member TurboGTP's Avatar
    Cali
    Ok i think i might just get that instead of buying the Intercooler Kit from ZZP & save some money.
    Show Me The Boost
  2. #2 Re: Upgraded to an A2A IC System.
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by TurboGTP View Post
    Be careful, I believe Sal uses the car mostly for drag, so he has his own reasons to delete the front bumper support. If you get a large enough front mount, you would most likely need to do this also. Its not totally unsafe, but it is another piece of metal protecting you from really messing up yourself or the car.
  3. #3 Re: Upgraded to an A2A IC System.
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    It will be cheaper to get all the piping and front mount on your own. You can get a smaller FM, model# TR10 (I think), that should fit behind the bumper support.
    I will be making a bar that will go across in front of my car soon. This way I am a little protected.
    I really only use my car on the weekend if I have a chance and at the track.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  4. #4 Re: Upgraded to an A2A IC System.
    Cali
    Quote Originally Posted by Silver2kgtp View Post
    Yea i was thinking on getting the TR10 Cause my car is going to be a Daliy Driver. Well not all the time but for most weekends.
    Show Me The Boost
  5. #5 Re: Upgraded to an A2A IC System.
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    i see u have 2 cradle spacers under the aluminum cradle. whats the reasoning? just wondering
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  6. #6 Re: Upgraded to an A2A IC System.
    Feb 2008
    NY
    Quote Originally Posted by bbptech View Post
    hood clearance because of the IC core under the intake. The SD hood was hitting with only one set of spacers.
  1. ABS System?
    By mcg_999 in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2008, 10:40 AM
  2. ABS System
    By Bonvoi29 in forum General Tech Discussion
    Last Post: 06-04-2008, 01:17 AM
  3. new car = new system
    By ninjamonkey in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2008, 05:43 PM
  4. How to put in a Nav system
    By gp04 in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2008, 12:33 AM
  5. My system right now
    By Grandprixboy1224 in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2008, 05:04 PM
