Thread: ....you know what it is... 700whp build
Results 1 to 20 of 274
  1. #1 Re: ....you know what it is... 700whp build
    Waukesha, WI
    swap in a turbo LS1 in the fiero, that should be fast. right?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: ....you know what it is... 700whp build
    Quincy, Mass
    Quote Originally Posted by redlinepontiac View Post
    turbo 3800 weighs less.
    No more GP 04 Impala SS Indy:
  3. #3 Re: ....you know what it is... 700whp build
    Jul 2010
    Houston, Texas, United States
    Nah ,try a twin turbo 572. That should do it.lol
  4. #4 Re: ....you know what it is... 700whp build
    GT Level Member RegalGS98s's Avatar
    NJ
    Lil late, but friend's Fiero that who knows how much money is in it had the LS1 in it, but figured out could go faster with the 3800 because it was lighter.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  5. #5 Re: ....you know what it is... 700whp build
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    Quote Originally Posted by RegalGS98s View Post
    the car is already xp cammed 3.8L l67
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  6. #6 Re: ....you know what it is... 700whp build
    Feb 2009
    flintnasty MI
    uh? Serious post? A LS1 is more than 80lbs lighter than a L67.
  7. #7 Re: ....you know what it is... 700whp build
    NJ
    Shoot, maybe it was the LT1 at the time. I was thinking to myself, the LS1 is aluminum, it should be lighter. It was probably about 10 years ago when he changed to the 3800. Though I almost thought there was a cast iron version of the LS1 people use on extreme builds cause he was going for crazy power over 1000hp.
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
