Thread: Crossover and DP
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 64
  1. #1 Crossover and DP
    Banned - Busted For Scamming
    Feb 2009
    Why the hell does zzp want so much for a crossover and downpipe? Its ridiculous, $500 for the crossover, another $600 for the downpipe? Thats crazy!!! Oh well, looks like ill be making my own.
  2. #2 Re: Crossover and DP
    Topeka, KS
    Their inter-cooler's are just as expensive. I think alot of mods for our cars are high. I look for deals on the interwebs.
  3. #3 Re: Crossover and DP
    Feb 2009
    Eh, ive found all the stuff on ebay i need to make my crossover and dp for $150.
  4. #4 Re: Crossover and DP
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    If you can Tig or Mig weld you can make all the piping yourself and save a butt load of cash. It also allows you to build your kit off your choice of turbo i.e flanges, on center, outlet sizes etc. For the I/C there are loads of options and cold piping well ebay is your best friend. Pipe kits go for sub $100.
    Anyways good luck with your setup bro!
    Speed is an addiction the faster you go the slower it becomes.
    01 GT | Matt's new TT cam | PT-67 | 18-22psi and a couple stock trannys.
  5. #5 Re: Crossover and DP
    Feb 2009
    Ive already picked everything out, i found all the stuff on ebay for killer prices. Yea i can mig good i was just wondering why they rip off the general populus. I will have 3" downpipe, v band, flex, catted, cutout 3". For the crossover, 2.25". I priced everything for the dp and crossover its like $150.
  6. #6 Re: Crossover and DP
    Jul 2008
    Germantown, Maryland
    Mini, do you by any chance have a TOGs crossover template? My Crossover is damaged and honestly is causing some serious restriction. If you can make me a crossover pipe I would seriously buy one.
    Thanks
  7. #7 Re: Crossover and DP
    Feb 2009
    Unfortunately i dont, sorry!! Cant you buy a new tog crossover? What is damaged about it?
  8. #8 Re: Crossover and DP
    Jan 1970
    Maquoketa, Iowa
    No one else makes them, zzp could charge whatever they want. The crossover is also only $250 unless you want the version with the wastegate on it. You could easily go open dump wastegate and run a 2.5" downpipe, which would equal out to your typical 3" downpipe setup.
    What type of steel are you using? Your going to want the smaller brake booster for a 3" dp as well.
  9. #9 Re: Crossover and DP
    Jul 2008
    Yea, I'm thinking of hitting one of the local sheet metal shops and seeing what they can do. I'm sure if I give them my crossover that is bent, they should be able to remake one for the correct size.
    Quote Originally Posted by FoSHO99 View Post
    How loud would an open dump wastegate be? It's got to be pretty insane consider those open wastegates are extremely loud on the DSMs.
  10. #10 Re: Crossover and DP
    Nov 2008
    NY
    How so?
    and open dump isn't too loud. No where near a 4g63. Then again depends on the wg you get too.
  11. #11 Re: Crossover and DP
    Jan 1970
    Maquoketa, Iowa
    In an open dump setup, your not returning the exhaust gas or pressures to the downpipe. So the downpipe turns into more like 2.5" downpipe + size of wastegate. It's also better at keeping a consistent psi. The only thing you have to deal with is the noise, which isn't too bad.
  12. #12 Re: Crossover and DP
    Nov 2008
    NY
    I understand where you are getting the idea but how do you equate running a open dump wg to relieving .5" of space from a 3" dp?
  13. #13 Re: Crossover and DP
    Feb 2009
    1. The $250 crossover is a retarded design. 2. Im going 3" dp, not open dump.
  14. #14 Re: Crossover and DP
    Nov 2008
    NY
    What design are you going with if I may ask?
  15. #15 Re: Crossover and DP
    Feb 2009
    The stattama design.
  16. #16 Re: Crossover and DP
    why no EWG? thats going to be one of the first things i do when i get a turbo car.
  17. #17 Re: Crossover and DP
    Feb 2009
    What?
  18. #18 Re: Crossover and DP
    external wastegate
    internal wastegates blow and you dont get that awesome sound.
  19. #19 Re: Crossover and DP
    Feb 2009
    What sound? Exhaust noise? Screw that.
  20. #20 Re: Crossover and DP
  1. ZZP Crossover Pipe
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2009, 04:46 PM
  2. Wrapping the crossover?
    By the1euge in forum General Tech Discussion
    Last Post: 04-20-2008, 07:04 PM
