Thread: Wrapping the crossover?
Results 1 to 9 of 9
  1. #1 Wrapping the crossover?
    SE Level Member the1euge's Avatar
    Apr 2008
    Pittsburgh, Pa
    Well i bought some crossover wrap and after reading a bit about it, i was wondering if its a good idea or not.
    I've seen that people have just wrapped the crossover saying not to use silicon spray on it because it will trap in water and rust the crossover.
    Others have said that you should use silicon on it so fluid doesn't drip on the wrap and ignite.
    Anyone know if its a good idea to do this at all, or what the best way is? also should i remove the crossover's heat shield and wrap, or just go straight over it?
  2. #2 Re: Wrapping the crossover?
    TDCRacing
    Guest
    Quote Originally Posted by the1euge View Post
    As far as i know you cant remove the heat sheild...and it def. wouldnt be bennefictial if you could
    There should not be and fluid dripping on the crossover...wrapped or not...if there is fix it now.
    I wrapped my crossover and i didnt use the spray.I dont beleive the spray would do that to the crossover as far as the rust goes...but that is just my opinion...there shouldnt be any water in the crossover or enough mostiure to do that to a crossover in my opinion
  3. #3 Re: Wrapping the crossover?
    Apr 2008
    Pittsburgh, Pa
    ok thanks for the quick reply. my crossover looks nice and clean so i might just wrap it up, at least until i get rid of my open cone setup and get something in a box
  4. #4 Re: Wrapping the crossover?
    GT Level Member Going Too Phast's Avatar
    There is a way to take off the factory heat shielding. You have to grind down three welds or so. I don't know if it is possible to do without taking the crossover out though. I just did a layer of wrap on top of the factory shielding. Spraying the wrap with silicone spray is safer but again, you'd have to remove the crossover to do it right. Unless you have a better reason for removing the crossover, it is way more trouble than it is worth. My wrapped and uncoated crossover has been doing fine for a few months now. Just don't spill flammable fluids on it. I'm going to be pulling out part of my exhaust out soon and I plan on coating the wrap at that time.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  5. #5 Re: Wrapping the crossover?
    Saraland Alabama
    I hate the wraps, I have seen too many headers rot from underneath to let me trust it
  6. #6 Re: Wrapping the crossover?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by archemedes View Post
    This is the reason I haven't wrapped mine.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  7. #7 Re: Wrapping the crossover?
    SE Level Member PitchBlackSS's Avatar
    Medford, NY (Long Island)
    mines wrapped, been on for over 3 years, no problems so far
    2004 Impala SS - I'm done modding, I swear
    My NAIOA Garage Page
  8. #8 Re: Wrapping the crossover?
    Topeka, KS
    You can remove the heat shield. It's not hard. I have mine wrapped with no probs. Keeps the heat off the intake and makes it easier to work on under the hood when every things hot.
  9. #9 Re: Wrapping the crossover?
    Apr 2008
    Pittsburgh, Pa
    well i did end up wrapping it but i'll probably take it off and see what it looks like underneath after some time just to be sure.
    question is though, and i forgot to look, is the crossover heatshield directly welded to the crossover, or can air/water pass between it? reason why im asking is that i only covered the heatshield area in hopes that any water that may get up inside would drain out or evaporate cleanly.
