No one else makes them, zzp could charge whatever they want. The crossover is also only $250 unless you want the version with the wastegate on it. You could easily go open dump wastegate and run a 2.5" downpipe, which would equal out to your typical 3" downpipe setup.
What type of steel are you using? Your going to want the smaller brake booster for a 3" dp as well.
