Thread: Track session, Win vs GT500 with whipple upgrade
Results 21 to 40 of 76
  1. #1 Re: Track session, Win vs GT500 with whipple upgrade
    Proof = believing
    Dont be calling any bullsh1t with me if thats what your intention is here im not sure if it is.....
    We all should know from nicks OMGTVS build stock injectors do not top out at 300.
    I guess long story short whats the point of getting dyno numbers? Guy can obviously tune and has slips to back it up!
    Thats plenty for my world
  2. #2 Re: Track session, Win vs GT500 with whipple upgrade
    Oct 2011
    Puyallup WA
    I think that broken 1st is really helping you!
    08 G8 GT - exhaust Tune
  3. #3 Re: Track session, Win vs GT500 with whipple upgrade
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    Quote Originally Posted by wa04compg View Post
    Yep I noticed it helped the 1st time I tried a run on the street.
    There is plenty torque in a FWD to start in 2nd. On a RWD setup I wouldn't do it.
  4. #4 Re: Track session, Win vs GT500 with whipple upgrade
    Oct 2011
    Puyallup WA
    Just spent alot on HPTuners and xp cam build...need to sell all my extra stuff to buy turbo stuff
  5. #5 Track session, Win vs GT500 with whipple upgrade
    May 2013
    Gatineau
    Scan of the 11.6 run see how i have to modulate throttle to ger back traction.
    17deg advance
    Injector duty cycle very high
    Maxed out maf i flow a lot more than 48/min
    A/f is 11.5
    Narrowband was on and off today, need a new one
    0-60mph 3.2 seconds on that run
    0-100mph is 7.5 seconds
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  6. #6 Re: Track session, Win vs GT500 with whipple upgrade
    2nd gear is 1.57:1 vs the 1st gear 2.92:1
    http://www.fastfieros.com/tech/4t65e...on_general.htm
    Transmission info gear ratios.
    http://www.dragtimes.com/horsepower-...calculator.php
    11.60 @ 120 with 3000 # vehicle weight (estimate) puts the HP figure at 392 @ the flywheel.
    Id have to believe that's pretty damn close. Of course actual vehicle weight will skew the HP figures but Id believe that is pretty damn close.
  7. #7 Re: Track session, Win vs GT500 with whipple upgrade
    May 2013
    Gatineau
    Dont forget my 220 lbs.
    Vehicule weight is race weight including driver. So 3200-3300lbs
  8. #8 Re: Track session, Win vs GT500 with whipple upgrade
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Damn, that's hauling the mail. Way to prove all the doubters wrong. That's awesome.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  9. #9 Re: Track session, Win vs GT500 with whipple upgrade
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    What doubters?? Its very easy to smash 12s and 11s with a turbo 3800. Just cost a hefty penny for a trans that can hold it plus the turbo kit.
    Wicked car man
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  10. #10 Re: Track session, Win vs GT500 with whipple upgrade
    Mar 2012
    NC
    I give you credit...I was in doubt that this was what you expected, but 11.606 is better than I placed you. Congrats on proving me wrong.
  11. #11 Re: Track session, Win vs GT500 with whipple upgrade
    May 2013
    Gatineau
    Thanks guys. What's the point of drag racing if not push the boundaries. In my case, I wanted a very cheap build that ran quick times and I'm happy with it.
    What to go one more step before going full out on the twin engine project.
  12. #12 Re: Track session, Win vs GT500 with whipple upgrade
    May 2013
    Gatineau
    Speaking of pushing boundaries...
    Just finished testing the car at 22.3 psi of boost.
    Unreal...
    10.9s is my goal but traction will have to be there. Plenty of power now to do it.
    Smoked the 26 X 10.5 X 15 E.T. Streets like they are an all season tire at speed up to 90 mph. No traction.
    Really dissapointed in the E.T. street tires in a FWD application. Tried different pressure, cold, hot, no difference. Traction similar to other drag radials (not good).
    Put back my 23" X 8.0 X 15 MT full slicks... Now we are talking. Much better spun to 70mph only ! lol
    Yet I need more traction my best 60 foot lsat Saturday was 1.85 average 1.9 - 2.0.
    Just getting a 1.6 60 foot would net me low 11s with the power I had before.
    So I will be ordering taller and wider slicks, and hopefully I will hook enough for a 10 second pass
    with stock injectors, stock MAF, stock engine and stock trans. Running 12.5 a/f ratio on race fuel now.
    conservative timing map and Zero KR.
    So far so good, testing on the street was very conclusive.
  13. #13 Re: Track session, Win vs GT500 with whipple upgrade
    Feb 2009
    flintnasty MI
    You are not even scanning the maf how would you even know its maxxed?
    If tuning the last cell of the maf is your idea of tuning then go for it but luckily the valve float will keep the airflow fairly fixed at rpm.
  14. #14 Re: Track session, Win vs GT500 with whipple upgrade
    May 2013
    Gatineau
    Your talking about valve float again ??
    Why is it I can raise boost and shift at 6400rpm and not lose any time on the 1/4 mile if I have valve float ??
    Please stop. What are you trying to prove, that I don't know what I'm doing ?
    Maxing the Maf and injectors is not something I would give a customer but for my own stuff it is safe.
    Because I constantly monitor knock and boost during a run.
    At this point I am getting zero KR, safe A/F ratio. So why would I hurt anything in the engine.
    Heck it has 150K miles that old engine on all original head gaskets.
  15. #15 Re: Track session, Win vs GT500 with whipple upgrade
    Feb 2009
    flintnasty MI
    Forgot about my buddy running rockers and 130s that traps 127 on 100octane at 2950lbs
  16. #16 Re: Track session, Win vs GT500 with whipple upgrade
    Feb 2009
    flintnasty MI
    Oh and flow more than 48lbm? Bull again.
    6 39# injectors flow 3.9lb/m worth of fuel. At 12.6afr thats 48lbm worth of air. On pump gas its 44lbm.
  17. #17 Re: Track session, Win vs GT500 with whipple upgrade
    May 2013
    Gatineau
    Your math got you nowhere in predicting my times or my HP.
    You math is wrong... there are MANY factors you don't understand and reading you just makes me cringe. Please stop.
    I can go 25 lbs of boost increase my power tremendously and then I will be full maxed out on stock injectors with my upgraded fuel pump/fuel cel I am running.
    You can believe in your own set in your mind limitations. I don't let that stop me.
    As long as A/F is safe and no KR, I am not worried. I'm only running TR6 plugs... Again a HUGE misconception to have to run colder plugs btw guys.
    If you have to run a much colder plus, the tune isn't right. Simple as that. I could be running stock plugs and not even have any pre-ignition because my tune is still safe.
    Regardless if I max out my maf or Injectors or both.
  18. #18 Re: Track session, Win vs GT500 with whipple upgrade
    Feb 2009
    flintnasty MI
    Its wastegated.. the valve float shows as a restriction in the intake as boost and opens the wastegate and the turbo doesnt spin faster. If you had a maf sensor you could see flow staying stagnant as boost goes up. You cant ass dyno valve float in a turbo car.
    Remember kid ive put 40k miles on a stock motor / trans setup identical running 16psi, and I am the fastest guy on this forum by hundreds of whp.... you keep calling me dumb and a hater telling you exactly whats going on. You have lied about your car many times already over the internet which makes it very hard to tell whats actually happening.
    The last 3000lb turbo car I tune was going 130mph on 93 octane a valve spring upgrade and a pt6262... so you have work to do to keep up let alone beat me on race gas.
  19. #19 Re: Track session, Win vs GT500 with whipple upgrade
    May 2013
    Gatineau
    Wrong... You make assumptions of things you know nothing about. You were the one saying my turbo would never work on my car.
    Again wrong.
    Smaller turbos DO NOT follow the same rules as bigger turbos. Biggers turbos require more exhaust pressure to sustain shaft speed and therefore BOOST. If you understood exactly how a turbo work, you would not have never made the above statement. You don't seem to understand the physics behind an engine or a turbocharger.
    My boost stays the same because my boost control is right AND because my turbo is well matched with my engine. Most of you guys go way to big in the turbocharger and have peaky powerbands. You make huge power at top RPM but nothing down low. It's less likely I break anything because I have a constant pull, no spike in power.
    I can't ass dyno valve float you can't detect it via internet either. I know what valve float is, I don't have any. There are symptoms on a turbo car when the valves start floating.
    Lied ? I've said nothing but the truth. Not my fault you misinterpret the data I feed you.
    And no I don't think your dumb, not yet. But I do think there are many things you do not understand. The limitations you are talking about and much further than what you are saying.
    You probably never tried exactly what I did. You most likely go for more expensive set ups from the get go and not learn anything about the true limits of the stock parts.
  20. #20 Re: Track session, Win vs GT500 with whipple upgrade
    Feb 2009
    flintnasty MI
    Oh and I never tried your setup? I just told you word for word I ran it for 2 years as a dd and already went faster than you becuase I spent the time to put the right injectors and maf on for $160.
  1. 2013 GT500 Launch Control
    By TLSheff in forum Off Topic Discussion
    Last Post: 07-06-2012, 07:10 PM
  2. shelby gt500
    By 99prixgt in forum Track Sessions and Kills
    Last Post: 09-19-2009, 11:01 PM
  3. fresh wash and mini photo session...
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 07-30-2009, 07:56 PM
  4. 2010 Ford Shelby GT500
    By Vespers47 in forum The Rant Forum
    Last Post: 01-17-2009, 09:43 PM
  5. gt500
    By 1badgp in forum Track Sessions and Kills
    Last Post: 07-24-2008, 09:07 PM
