Thread: Interpreting scan logs, any help please?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 80
  1. #1 Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    OK, I'm pretty sure I've worked out the mechanical bugs. Car is drivable. Went for a short drive tonight so I can begin trying to figure out these scan logs. I am not hammering the throttle, just rolling into it. Not going much over 65% tp. That's because I'm seeing kr. It happens when MAF frequency hits about 8000. My ltft is around -1.5. Stft -5. KR is up to 5-6. Well, I'll post a log if anyone is interested, but basically I'm wanting to know how I relate these points to the spark table? The spark is in Mg/cylinder. And MAF is in hz. Is there a formula to figure out what points I should be pulling spark?
    Right now I'm using the L67 spark table. I imagine I'll need to trim some spark since I'm running more compression. Just don't know how to find the points in the spark table to pull. I googled and found a formula, but its for a v8.
    I have tried using Jerry's guide to tune ve first. But my car won't run with the MAF unplugged. As soon as I hit boost the car dies. No idea why this is.
    Top Swapped 01 Imp
  2. #2 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Here is the log if anyone has time to look. Around line 1200 was one problem area.
    https://www.dropbox.com/s/ulyhzb785z...1scan.xml?dl=0
    Top Swapped 01 Imp
  3. #3 Re: Interpreting scan logs, any help please?
    The VE table on a supercharged PCM stops at 140 kpa, not even really 4-5 psi of boost, the car is not meant to use the VE table.
    It takes everything from the MAF sensor and MAP sensor.
    I have no idea what that is in the dropbox, I use hpt so I don't know anything aobut dhp if that what that was.
  4. #4 Re: Interpreting scan logs, any help please?
    Kemmerer, Wyoming
    You need to export it in .csv so we can read the file
  5. #5 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Top Swapped 01 Imp
  6. #6 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    It's as soon as I hit boost, 100 kpa it just dies like i turned the key off. Have to let it sit for 15 seconds before it will start. Dunno if it's flooding or what.
    Top Swapped 01 Imp
  7. #7 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    The ADC input 2 is my wideband. I got the formula working but it stops responding after a couple minutes. Need to get ahold of AVT and see what's going on.
    Top Swapped 01 Imp
  8. #8 Re: Interpreting scan logs, any help please?
    Kemmerer, Wyoming
    I looked at it, I am too much of a noob tuner to make any real suggestions, other than your fuel trims need a lot of work
  9. #9 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by SgtMarshal View Post
    Lol, thanks Captain Obvious
    Top Swapped 01 Imp
  10. #10 Re: Interpreting scan logs, any help please?
    Grand Island, Nebraska
    If you are running a 3.4 pulley that is too much for a top swap. I need to be on E85 in order to run that pulley.
    And just to double check, you are using an L67 MAP and tune right? I dont think the L36 tunes like to see boost.
    Third, what is that A/F column? commanded Air/fuel? because every time it drops to <14.7 is when it starts to knock. I can't tell if this is the cause or an effect.
  11. #11 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by JoRoW99 View Post
    You have identical setup. I can get a bigger pulley, but I'm going e85 too. Was just trying to get something drivable for a tank or two of 93. Gives me a chance to figure some of this tuning out.
    Yes I have l67 map and tune. The A/F column is commanded I think. DHP is not liking my WB for some reason.
    I just had an aha moment. Not sure if its right. But what I could do is look at the spark advance and use that to figure where I need to pull timing in the table.
    Top Swapped 01 Imp
  12. #12 Re: Interpreting scan logs, any help please?
    Kemmerer, Wyoming
    I've been using an Innovate MTX-L wideband with UVscan and it seems to work well. I'm not sure if timing advance is your problem because when you have the KR and your timing drops to about 10, the KR doesn't go away. Putting a bigger pulley on might be the solution.
  13. #13 Re: Interpreting scan logs, any help please?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    MAF Decade Average of KR Average of LTFT Average of Injector PW Average of MAP(kPa) Average of O2
    0 0 2.34375 2.782110039 98.97674419 4.239069767
    1 0 2.34375 3.207446403 95.6 4.34
    2 0 9.095982143 2.360037505 45.05791506 429.5427027
    3 0.003202492 4.235197368 3.129520369 50.99595142 488.8561943
    4 0.013090093 -3.607047872 4.158786897 59.5106383 491.5588652
    5 0.090921336 -4.579741379 5.791851156 74.4137931 537.3368966
    6 0.289667694 -5.094630282 7.378059461 91.42253521 536.9374648
    7 0.82108347 -3.700657895 10.27494348 117.4473684 591.7247368
    8 3.598632813 -0.607638889 13.96709138 136.2222222 911.6411111
    Your trims are very lean at idle and cruise (MAF decades 2 and 3). When you start getting into load (MAF decades 4 and up) at throttle tip-in, you are weak in the PE transition and get the KR. Look at your frames in the 250 - 260 range. Your LTFT shoots up to 10% because you can't keep up the fuel. You need to richen up the MAF curve in the lower ranges and check your PE transition throttle settings, and then adjust PE fueling for added richening.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  14. #14 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Thanks guys! I may have some bad data though. I found another exhaust leak pre o2 sensor. Could that be why the trims go way high especially on decel? A few times my car also died when I slowed to stop. I aimed a leaf blower at the exhaust and found a nice one where the crossover connects to the rear header. I'm gonna let the rtv set and take it for another drive later.
    Sorry, feel like I kinda wasted your time. I'll make sure its not leaking before I post another log.
    Top Swapped 01 Imp
  15. #15 Re: Interpreting scan logs, any help please?
    A trick I used to find exhaust leaks was to put a rag or something in one of the tailpipes and then seafoam if. the white smoke will come out of the leak.
  16. #16 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    That's a good trick. I'll remember that. Tough to do the rag trick when you're alone though. Used the vac because I wanted to get working without waiting for pipes to cool.
    Top Swapped 01 Imp
  17. #17 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by mguzzo View Post
    Could this be because my IFR is off? Stock L36 IFR is one value in the whole table. The L67 IFR is scaled down the list. I've seen both methods used in topswaps. Mine are scaled starting at 219 something.
    Top Swapped 01 Imp
  18. #18 Re: Interpreting scan logs, any help please?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    First problem I see, beside the obvious LTFT's needing fixed, is that when you're in boost, you're still not in PE and your afr is at 14.7. Under PE_Enable_TPS, it should be set to whatever tp% you start getting into boost at. Looking at your scan, that's just over 30%, I have mine set at 35%. It looks like you're not seeing PE until 50% throttle, and even then a commanded 13.1-13.0 afr is too lean. Any way you could add your .bin to the dropbox so we could take a look at it?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  19. #19 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Sure, thanks. Here is the bin. I get what you are saying. How exactly do you tell when i'm in PE looking at the scans? Is it when the AFR changes? So, when just cruising the car is using MAF table, but when I step on the throttle, PE table is used once TPS reaches the set value?
    Top Swapped 01 Imp
  20. #20 Re: Interpreting scan logs, any help please?
    Cibolo, TX
    Yeah, you can tell you're in PE when your AFR changes, looks to be right about 50% for you, but you start seeing boost at ~30%. Gonna take a look at your .bin.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. PRJ Fuel logs
    By Javi in forum Wanted To Buy - Parts
    Last Post: 02-05-2015, 11:38 AM
  2. Fuel Logs, 42.5's
    By Dtrick22 in forum Wanted To Buy - Parts
    Last Post: 02-28-2014, 01:18 PM
  3. Interpreting torque specs.
    By NinetyEightGTP in forum General Grand Prix Discussion
    Last Post: 07-04-2013, 10:05 PM
  4. WTB: Fuel Logs
    By 1999black3800 in forum Wanted To Buy - Parts
    Last Post: 03-16-2013, 09:49 AM
