Thread: Interpreting torque specs.
Results 1 to 5 of 5
  1. #1 Interpreting torque specs.
    Jun 2012
    Southern NJ
    I swapped my new 105lb valve springs onto my heads (I still need to do a valve job, actually) but I was wondering how I'm supposed to interpret these torque specs I found from WBS for the rocker arm bolts:
    Valve Rocker Arm Bolt 15 + 90?Nm (11 + 90?ft. lbs.)
  2. #2 Re: Interpreting torque specs.
    Donating Users akarana23's Avatar
    West Bloomfield, MI
    I did 25ft/lbs for each rocker bolt, and so far no problems. That's what one of the mods here recommended to me, make sure to use a little loc-tite on them too.
  3. #3 Re: Interpreting torque specs.
    Quote Originally Posted by akarana23 View Post
    This
    04 Comp G.
  4. #4 Re: Interpreting torque specs.
    Jun 2012
    Southern NJ
    Thanks dude. I was just worried about over-torquing.
  5. #5 Re: Interpreting torque specs.
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    But how you read that is 11 ft lbs + 90 degrees, so you go till it clicks and another 1/4 turn past it to set the TTY bolt. But if you are using reuseable bolts that doesen't fly.
  1. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  2. torque specs
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2010, 11:37 PM
  3. Torque specs
    By projectGTP in forum General Tech Discussion
    Last Post: 03-25-2009, 07:31 AM
  4. i need torque specs
    By MTXGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2008, 12:14 PM
  5. Looking For Some Torque Specs.
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 07-10-2008, 02:58 PM
