First problem I see, beside the obvious LTFT's needing fixed, is that when you're in boost, you're still not in PE and your afr is at 14.7. Under PE_Enable_TPS, it should be set to whatever tp% you start getting into boost at. Looking at your scan, that's just over 30%, I have mine set at 35%. It looks like you're not seeing PE until 50% throttle, and even then a commanded 13.1-13.0 afr is too lean. Any way you could add your .bin to the dropbox so we could take a look at it?
