Thread: Any way to have multiple tunes and switch between them, without reflashing?
Results 1 to 20 of 27
  1. #1 Any way to have multiple tunes and switch between them, without reflashing?
    GXP Level Member
    Mar 2015
    Tomball
    Back when I was messing with EEC-IV's Diablosport had a device out where you could switch up to I think it was 5 different tunes.
    I'm thinking to the future after I get the car running correctly.
    So say I wanted to swap to larger injectors and have a tune for gas and change to E85 when I go to the track. Or if I wanted to limit power if I valet park or anything like that. Is there such an animal out there that you can accomplish this without connecting a laptop?
    Jeff
  2. #2 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Not that I know of.
    You still have to re-flash the computer to make any changes. DHP, HPT all require you to write to the PCM to change anything.
  3. #3 Re: Any way to have multiple tunes and switch between them, without reflashing?
    dont greg have a valet key and programming on the whipple car?
  4. #4 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Who knows, and who cares.
  5. #5 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GXP Level Member
    Mar 2015
    Tomball
    Ok, thanks. I hadn't seen anything, just wondering if I missed something, guess that's better than nothing. I'm still researching what I should go with.
    Jeff
  6. #6 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Interesting idea. I suppose you could wire up 2 PCMs, then have some kind of switch to control which PCM is active...
    The first problem I could see though, would be that if you switched off one PCM, drove the car on a 2nd PCM, then went back to the first PCM... then you'd probably need to do a CASE learn afterward. Perhaps there would be a way around that (say switch off the outputs but leave the inputs active).
    Perhaps a different way to accomplish your goals would be a happy knob or switch and tuning to make the knob/switch very effective? Then you could add/remove say 5 degrees of timing on the fly. You could wire the same switch to turn performance shift on/off... might give you some kind of "track mode".
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: Any way to have multiple tunes and switch between them, without reflashing?
    the problem is the pcm has what? 200 wires leading to it? now make that switch, i dare ya.
    once a pcm has been ran in your car and its security is learned and it didnt ask for a crank learn, or you did the crank learn its golden forever. you can take them in and out back and fourth all day long, the car will just fire up and run like it should.
  8. #8 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Quote Originally Posted by ScottyBDoggs View Post
  9. #9 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Nov 2012
    pistolvania
    [youtube]=nuHfVn_cfHU[youtube] well that didnt work hmmm
  10. #10 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GXP Level Member
    Mar 2015
    Tomball
    I think it would be quicker for me to just have an E85 and a gas tune maybe a 87 octane tune as well. Then just switch them out manually. I just figured that there must be something out there.
    That is an idea to switch from one to the other. I've made redundant PLC control panels for critical applications, and it only takes 1 relay for each set (1 normally open and the other normally closed) and an A/B switch, but for the PCM that would take a relay bank 20" by 10" and heaven forbid a relay goes out lol.
    Jeff
  11. #11 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Knoxville, TN
    I guess if you're trying to use some switches you found at radio shack, yeah, you'd have issues... but they do make switches with enough connections that work properly for the application. Or you can just program a PLC with some relays, even an old Micrologix can do this quite easily. I've programmed them for similar functions.
    I'm not saying it would be practical, but most automation supply stores would have what you need to build a system.
    As far as the CASE learn... that's good info, it was my (mis)understanding that a CASE learn was required any time an engine was run/turned over with the PCM disconnected.
    Edit... should have read that J57ltr already covered the PLC bit.
  12. #12 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Apr 2015
    Columbus, OH
    It would be nice to have the ability to flip a switch for e85/93. There is "performance" mode in the trans settings. Seems with the right table tweaks you should be able to put "performance mode" into other areas like fuel and spark. Maybe with the right software. Maybe ATuner will have this ability?
    Side note, how difficult is it to add a performance button to a car without one? Would you just put the right pin in the pcm and have a switch that grounds it when flipped on?
    Top Swapped 01 Imp
  13. #13 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Quote Originally Posted by bandook View Post
    just learned this one myself. its 2 things in dhp you change, and then add a pcm pin and wire to pin# 21 on the clear plug to the switch, ground the other side of the switch.
    if you dont tune the pcm to know all your doing is turning on the light in the dash. some dont even have the light bulb install.
  14. #14 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GXP Level Member
    Mar 2015
    Tomball
    I wonder what other inputs are not used on the PCM and is there a way to program their functions? Is there enough memory to store 2 profiles?
    Jeff
  15. #15 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Nov 2011
    NY
    There was definitely a write up on this before... Dual pcms, dual programs. Personally, I don't see the problem with just bringing your laptop and dropping the tune you need for what you're doing at the time, ie, track. But that's just me : )
  16. #16 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Knoxville, TN
    Quote Originally Posted by coolone View Post
    Yeah, this would be the smart/practical idea for sure. Heck, even a cheap little netbook can do this... maybe just keep an old laptop in your car just for this purpose? People are even tuning with tablets now, it seems. I wouldn't be terribly surprised if someone figures out a way to flash the PCM from a smart phone.
  17. #17 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GXP Level Member
    Mar 2015
    Tomball
    I'll take a look at seeing if I can find that write up, thanks for tip, I did a search but didn't see anything, but didn't know what terms to search so I was using Diablosport and such. As far as using a laptop, I understand, but once you have everything set then why not be able to switch almost on the fly? I mean if this was available for Fords back in the late 90's why wouldn't it be available 10 years later for GM products? Yes different systems and all, just thought we'd be farther than this.
    as far as doing this with a PLC, it's not even complicated enough for that, besides too many I/O and too much analog. The systems I did had 64 inputs and 32 outputs and no analog. I used 4 pole relays to have PLC A on the NC contacts PLC B on the NO contact and the system on the common. A switch to select A or B, simple. With relay contacts you can pass analog signals easily for most signals. It's still not very practical.
    Jeff
  18. #18 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by Impala131 View Post
    now that's what I'm talkin' about.
    Jeff
  19. #19 Re: Any way to have multiple tunes and switch between them, without reflashing?
    May 2012
    Where winter never ends
    There was a socket made in Australia that when soldered in allowed for a secondary EEPROM and with the flip of a switch the active program was selected. No idea its status or where to find one
    Sent from my VS986 using Tapatalk
    2000 Regal - Winter Beater
  20. #20 Re: Any way to have multiple tunes and switch between them, without reflashing?
    May 2012
    the socket would need to fit an Intel intel ab28f400b5 EEPROM.
  1. GXP Tunes Repository
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 05-12-2015, 09:00 PM
  2. Multiple Engine codes - Multiple Cylinder misfire etc...
    By mrfreez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2014, 04:31 PM
  3. DHP 1.0 Tunes
    By RivMan in forum PCM Tuning
    Last Post: 12-02-2012, 02:53 PM
  4. E85 tunes
    By Hawkman in forum Midwest
    Last Post: 10-11-2011, 08:51 PM
