Thread: Any way to have multiple tunes and switch between them, without reflashing?
Results 1 to 20 of 27
  1. #1 Re: Any way to have multiple tunes and switch between them, without reflashing?
    the problem is the pcm has what? 200 wires leading to it? now make that switch, i dare ya.
    once a pcm has been ran in your car and its security is learned and it didnt ask for a crank learn, or you did the crank learn its golden forever. you can take them in and out back and fourth all day long, the car will just fire up and run like it should.
  2. #2 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Quote Originally Posted by ScottyBDoggs View Post
  3. #3 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I guess if you're trying to use some switches you found at radio shack, yeah, you'd have issues... but they do make switches with enough connections that work properly for the application. Or you can just program a PLC with some relays, even an old Micrologix can do this quite easily. I've programmed them for similar functions.
    I'm not saying it would be practical, but most automation supply stores would have what you need to build a system.
    As far as the CASE learn... that's good info, it was my (mis)understanding that a CASE learn was required any time an engine was run/turned over with the PCM disconnected.
    Edit... should have read that J57ltr already covered the PLC bit.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. GXP Tunes Repository
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 05-12-2015, 09:00 PM
  2. Multiple Engine codes - Multiple Cylinder misfire etc...
    By mrfreez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2014, 04:31 PM
  3. DHP 1.0 Tunes
    By RivMan in forum PCM Tuning
    Last Post: 12-02-2012, 02:53 PM
  4. E85 tunes
    By Hawkman in forum Midwest
    Last Post: 10-11-2011, 08:51 PM
