Thread: Any way to have multiple tunes and switch between them, without reflashing?
Results 1 to 20 of 27
  1. #1 Re: Any way to have multiple tunes and switch between them, without reflashing?
    Nov 2011
    NY
    There was definitely a write up on this before... Dual pcms, dual programs. Personally, I don't see the problem with just bringing your laptop and dropping the tune you need for what you're doing at the time, ie, track. But that's just me : )
  2. #2 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by coolone View Post
    Yeah, this would be the smart/practical idea for sure. Heck, even a cheap little netbook can do this... maybe just keep an old laptop in your car just for this purpose? People are even tuning with tablets now, it seems. I wouldn't be terribly surprised if someone figures out a way to flash the PCM from a smart phone.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  3. #3 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by Impala131 View Post
    now that's what I'm talkin' about.
    Jeff
  4. #4 Re: Any way to have multiple tunes and switch between them, without reflashing?
    GXP Level Member
    Mar 2015
    Tomball
    I'll take a look at seeing if I can find that write up, thanks for tip, I did a search but didn't see anything, but didn't know what terms to search so I was using Diablosport and such. As far as using a laptop, I understand, but once you have everything set then why not be able to switch almost on the fly? I mean if this was available for Fords back in the late 90's why wouldn't it be available 10 years later for GM products? Yes different systems and all, just thought we'd be farther than this.
    as far as doing this with a PLC, it's not even complicated enough for that, besides too many I/O and too much analog. The systems I did had 64 inputs and 32 outputs and no analog. I used 4 pole relays to have PLC A on the NC contacts PLC B on the NO contact and the system on the common. A switch to select A or B, simple. With relay contacts you can pass analog signals easily for most signals. It's still not very practical.
    Jeff
  1. GXP Tunes Repository
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 05-12-2015, 09:00 PM
  2. Multiple Engine codes - Multiple Cylinder misfire etc...
    By mrfreez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2014, 04:31 PM
  3. DHP 1.0 Tunes
    By RivMan in forum PCM Tuning
    Last Post: 12-02-2012, 02:53 PM
  4. E85 tunes
    By Hawkman in forum Midwest
    Last Post: 10-11-2011, 08:51 PM
