" I got a cel for maf and map uncalibration or some ****. So i cleared them and was able to start the car and get home. Do i need to do a case learn or should i flash the car to stock and go from there?"
Check the vac line to the map sensor, and make sure the map sensor is plugged in. I had this and it was because the map had lost vaccum. Make sure everything is sealed up properly (Lim, Blower). Sounds like you have a nasty vac leak, or need a tune hella bad.
