so I bought this programmer and I have a couple questions hopefully someone could shed some light on...
first, when I push the pedal all the way the LCD is reading the TPS is only at 89% not 100%. could this mean I have a vacuum leak or is this normal?
it also reads 56% for the MAP/MAF at WOT... could this also be caused from a leak?
I do know that my EGR is leaking and I bought the block off plate to install just curious as how to do so? do I just pull of the canister and unplug the wires then just block it off? or do I have to disconnect the wires from the source and remove all other parts? is there possibly a write up about this I've searched the forums but cant find anything on it.
Thanks in advance for any info![]()
