Thread: DHP Tuners newbie help please
Results 1 to 6 of 6
  1. #1 DHP Tuners newbie help please
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    Hey all I just bought DHP from a guy on W-Body.. I'd be extremely thankful if anyone can direct me where to read/watch videos anything to get some knowledge about modifying my PCM. I have a 1997 GTP if that matters basically stock my MAIN reason for purchasing DHP is fuel economy and some other stuff I have a ZZP 1.0 PCM which was edited by a guy I know he said he put the fuel tables from 04+ and that would help and I do believe him BUT I also know he didn't take time to go over everything and you can't have a real tune on 1 test. So like I said if anyone can help it would be soooo greatly appreciated! Thanks!
    ZZP 10.3mm Wires, Autolite 605s, CAI, HP Tuners PCM,
    3" Catted DP, Straight Piped, 20% Tint, 5k HIDs, 6k Fogs
    220a (eBay) Alt , RF Prime Amp 1333w (RMS), Kicker 12" L7 750w (RMS), RF PBR Amp 75w (RMS x4)
    Alpine Type R (Front 5.25" 90w (RMS Each), Rear 6"x9" 100w (RMS Each)
  2. #2 Re: DHP Tuners newbie help please
    FYI, your timing will read as a negative number. That's normal for 97. No idea why GM did it that way.
  3. #3 Re: DHP Tuners newbie help please
    Arizona
    Why would he utilise 04 tables...aren't 04+ return less? Which means it'll be irrelevant on a system with a return
  4. #4 Re: DHP Tuners newbie help please
    PS.. link to dropbox sent. I suggest d/l everything. Makes for a good start if you ever need stuff.
  5. #5 Re: DHP Tuners newbie help please
    SE Level Member Jeckel's Avatar
    Feb 2010
    Nampa, ID
    Can I get said link as well?
  6. #6 Re: DHP Tuners newbie help please
    I bet the guy meant timing tables. Most use the 05 GTP timing tables and then drop down the cruise section based on knock etc.
  1. HP Tuners
    By Sandman in forum Wanted To Buy - Parts
    Last Post: 01-09-2014, 06:10 PM
  2. Hp tuners with 06 gp gt
    By 38turbo in forum PCM Tuning
    Last Post: 03-12-2012, 10:29 AM
  3. HP tuners with an '05 GP?
    By DanGTP in forum PCM Tuning
    Last Post: 09-20-2008, 05:26 PM
