Thread: HPT Timing advance unsupported? Please Help!
Results 1 to 20 of 25
  1. #1 HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    Bought HPT pro couple days ago and with vcm scanner will not show timing advance...tried adding it though PID and there isn't even a advance drop down like there is with my silverado....hooked it up to silverado and its reading timing just fine...my friends HPT scanner has been hooked up to this multiple times and has always worked fine...I got most recent update still nothing....please help need to tune this xp cam
    08 G8 GT - exhaust Tune
  2. #2 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    My aeroforce see timing no prob
  3. #3 Re: HPT Timing advance unsupported? Please Help!
    You must be logging it in the table display for it to show it in the gauges or charts.
  4. #4 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    It doesn't show up in table even when I try to add it...the whole advance section is missing
  5. #5 Re: HPT Timing advance unsupported? Please Help!
    Go to open config file, click default and it will be there.
    It's always there on the default, you can even delete it from the primary table and then right click and insert > pid > engine > advance > timing SAE.
  6. #6 Re: HPT Timing advance unsupported? Please Help!
    Arizona
    Post the .cfg file
  7. #7 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    I have tried attaching the file won't let me
  8. #8 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    Anyone have a 04 config that I can try to use
  9. #9 Re: HPT Timing advance unsupported? Please Help!
    PM me on HPT, My name is 5FDP.
    I'll send you the config I use for my car.
  10. #10 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    I pm'ed you
  11. #11 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    So through the default I was able to go to histogram settings and make it work but half the other crap stopped working this is quickly turning into a pain
  12. #12 Re: HPT Timing advance unsupported? Please Help!
    Let me know if it works or not.
  13. #13 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    Shows timing as unsupported
  14. #14 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
  15. #15 Re: HPT Timing advance unsupported? Please Help!
    Very odd, my hpt scanner doesnt even have an IDLE for the pid list. Perhaps 04+ got a new setup that 97-03 didnt use.
    It's just general, airflow, advance, tq mngt and emission.
    Are you sure it's not like listed under general or something else on your screen??
  16. #16 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    Yeah I have looked in like every section...i emailed tech support and they shot me back something to try so I give it a try tomorow...got a WB on the way so hopefully can get all this cleared up before that gets here
  17. #17 Re: HPT Timing advance unsupported? Please Help!
    Hmm.
    What else really grinds my gears about HPT is that you always have to go out and connect to the vehicle you want to make changes on for a config file. Because if you clear the most recent vehicle under that tab it will just revert back to the default and show a million unsupported crap and you can't edit anything without starting over from scratch. I really really wish they would just allow you to open whatever config you want and then just start editing it from there.
  18. #18 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    Yeah thats what kept happening to me today would pop up config files that I didn't want
  19. #19 Re: HPT Timing advance unsupported? Please Help!
    Arizona
    That's why you make a seperat hpt folder in place of the default one on your computer so you can have exactly what you want
  20. #20 Re: HPT Timing advance unsupported? Please Help!
    Oct 2011
    Puyallup WA
    Hpt support got back to me and said to delete my .os file so I will be giving that a try tonight
  1. Kr/ timing advance
    By duswickware in forum General Tech Discussion
    Last Post: 05-26-2014, 08:58 PM
  2. timing advance
    By hollas13 in forum General Tech Discussion
    Last Post: 07-22-2013, 10:46 AM
  3. Timing advance and afrs
    By blackflag in forum General Tech Discussion
    Last Post: 05-25-2012, 04:55 AM
  4. Kr via timing advance?
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 02-06-2012, 12:33 PM
  5. what to expect with timing advance
    By TehGTP in forum PCM Tuning
    Last Post: 12-07-2008, 08:05 PM
