Thread: Kr/ timing advance
Results 1 to 12 of 12
  1. #1 Kr/ timing advance
    SE Level Member duswickware's Avatar
    Jan 2014
    mansfield, ohio
    So on the way home I noticed my kr was at 3.7 and timing advance was at 35. This was going from 60 to 80 on a pull jus to see...I know all stock will have kr but not sure if the timing is normal or not.
  2. #2 Re: Kr/ timing advance
    Jul 2013
    adrian, mi
    Kr seems normal for stock. The timing advance should be read at the lowest number seen. 35* sounds like you were just cruising. Wot should probably be around 16*. Maybe some one else will chime in and correct me if I'm wrong.
  3. #3 Re: Kr/ timing advance
    Jan 2014
    mansfield, ohio
    Timing may have been after..not sure. Today kr read 6.1* and timing stayed at 25 the whole time, not sure it was working or not. Did notice my fuel trims are far apart. Short term 1.9 negetive and long is 10.xx positive.
  4. #4 Re: Kr/ timing advance
    Jul 2013
    adrian, mi
    where in ohio are you located?
  5. #5 Re: Kr/ timing advance
    Jul 2013
    adrian, mi
    kr might jump around. i seen anywhere from 3*-5* when i was stock. my advance was about 14.5 wot and 27-28 cruising
  6. #6 Re: Kr/ timing advance
    Jan 2014
    mansfield, ohio
    Mansfield...its between columbus and akron
  7. #7 Re: Kr/ timing advance
    Jul 2013
    adrian, mi
    yeah im from Toledo. there is a big meet up in Detroit on the 14th of june lots of guys tuning and what not car show all sorts of stuff
  8. #8 Re: Kr/ timing advance
    Oct 2011
    Toledo, OH
    Quote Originally Posted by hollas13 View Post
    In Toledo or from Toledo? (Your info says Ft. Meade)
    7"
  9. #9 Re: Kr/ timing advance
    Jul 2013
    adrian, mi
    active army. im from Toledo trying to make it back for this meet up in Detroit and Norwalk for Pontiac nationals in august.
  10. #10 Re: Kr/ timing advance
    Oct 2011
    Toledo, OH
    I'm headed to the Detroit thing on the Saturday along with another Toledoen with a Regal 3800. Trying to see if Toledo works for a central point of meet for others too.
    7"
  11. #11 Re: Kr/ timing advance
    Jan 2014
    mansfield, ohio
    Not sure I trust the thing eenough yet to drive a distance...at least till I get all the kinks figured out...as of today fuel trims are looking better timing advance I don't think is working since its staying at the s.ame number on dofferent days...amazing what some sea foam and new fuel filter will do lol
  12. #12 Re: Kr/ timing advance
    Jul 2013
    adrian, mi
    sure does. a few friends of mine from out in the genoa Woodville area are going to.
  1. timing advance
    By hollas13 in forum General Tech Discussion
    Last Post: 07-22-2013, 10:46 AM
  2. Timing advance and afrs
    By blackflag in forum General Tech Discussion
    Last Post: 05-25-2012, 04:55 AM
  3. Kr via timing advance?
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 02-06-2012, 12:33 PM
  4. Stock timing advance for 98 GTP???
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2011, 09:55 PM
  5. what to expect with timing advance
    By TehGTP in forum PCM Tuning
    Last Post: 12-07-2008, 08:05 PM
