Thread: Kr via timing advance?
Results 1 to 7 of 7
99PontiacGTP Kr via timing advance? 02-05-2012, 06:11 PM
Fivefingerdeathpunch Re: Kr via timing advance? 02-05-2012, 06:15 PM
99PontiacGTP Re: Kr via timing advance? 02-05-2012, 06:30 PM
Fivefingerdeathpunch Re: Kr via timing advance? 02-05-2012, 06:34 PM
matt5112 Re: Kr via timing advance? 02-05-2012, 07:19 PM
darkhorizon Re: Kr via timing advance? 02-06-2012, 12:33 PM
99PontiacGTP Re: Kr via timing advance? 02-05-2012, 08:52 PM
  1. #1 Kr via timing advance?
    Sep 2011
    MI
    As the title implies: Is there any way to know if you have KR just by the Timing Advance values?
    I ask because my scan tool shows Ignition advance, but not a KR value....
    Thanks
  2. #2 Re: Kr via timing advance?
    If you are stock you will have kr, all stock grand prixs will.
    At wot, If i took a rough guess it will be about 15-16* ign adv, with anywhere from 2-5* degrees of kr.
  3. #3 Re: Kr via timing advance?
    Sep 2011
    MI
    So if I'm not stock that would change? or would that advance equal roughly that amount of KR?
  4. #4 Re: Kr via timing advance?
    Like say you have headers, that right there frees up all the exhaust restriction, no more u bend and small casted front manifold.
    With those, on a stock tune still, I would say all the KR would go away and it would be running at the exact commanded AFR and ign adv.
    Basically, exhaust mods get rid of knock and allow the car to breath.
  5. #5 Re: Kr via timing advance?
    Not really reliable method unfortunately.
    Timing modifiers can change things.
  6. #6 Re: Kr via timing advance?
    Feb 2009
    flintnasty MI
    Only in extreme situations... I have used this method and it works without issue. If you have a stock car making less than 15 degrees of timing, you can count on having 2-3 KR... Also nothing will put big bumps in timing curves except for KR.
  7. #7 Re: Kr via timing advance?
    Sep 2011
    MI
    bit the bullet and got a scanguage. thanks for the help though!
  1. Hey all, and THANKS in advance:)
    By rschap1 in forum Introductions/Noob Questions
    Last Post: 10-17-2011, 02:32 PM
  2. oem or advance auto?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 06-23-2011, 11:42 AM
  3. Stock timing advance for 98 GTP???
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2011, 09:55 PM
  4. Whats normal timing advance at idle?
    By goldgp in forum PCM Tuning
    Last Post: 03-29-2010, 10:18 PM
  5. what to expect with timing advance
    By TehGTP in forum PCM Tuning
    Last Post: 12-07-2008, 08:05 PM
