Thread: 05 gtp afr keeps changing
Results 1 to 7 of 7
  1. #1 05 gtp afr keeps changing
    Jun 2013
    Hollywood ,FL
    Got a tuning question for you i have a 05 gtp now when my tuner tunes my car we get the afr set right today it was 11.0 I know a lil rich now seems after about thirty minutes the car wants to change the afr in second gear to 12-13 causing knock does my tuner need to run open loop on the tune what could be going wrong that the car changes the fuel trims?
    Sent from my SGH-T999N using Tapatalk
  2. #2 Re: 05 gtp afr keeps changing
    Are you going by commanded and actual AFR with a wideband?
    Setting commanded AFR to 11 is easy and fuel trims will not pull that much fueling if any at WOT with these dumb pcm's.
    Perhaps you have a real fueling problem, like a failing pump or clogged fuel filter if you are commanding 11.0 but are seeing over 12 on the wideband. Watching injector duty cycle is anything to watch, you could be maxing them.
  3. #3 Re: 05 gtp afr keeps changing
    Jun 2013
    Hollywood ,FL
    Ok good so here's the thing im on 60# injectors running a zzp 350lph pump with rewire all bolt ons xp cam 3.4 pulley and my idc is 85% which has to be way to high
  4. #4 Re: 05 gtp afr keeps changing
    Is the right stuff for the 60 lbs injectors inside the tune?
  5. #5 Re: 05 gtp afr keeps changing
    Jun 2013
    Hollywood ,FL
    Lq4 maf and table for 60 are loaded already
  6. #6 Re: 05 gtp afr keeps changing
    Feb 2009
    flintnasty MI
    If you have an 05+ you probably have the wrong idc formula in whatever scanner you have.
  7. #7 Re: 05 gtp afr keeps changing
    Jun 2013
    Hollywood ,FL
    Oh really how do u change idc formula?
  1. changing pcm
    By Tyler Sharp in forum PCM Tuning
    Last Post: 08-07-2012, 10:09 PM
  2. changing SC oil
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2011, 02:01 PM
  3. Tried changing the S/C oil...
    By tayl5645 in forum General Tech Discussion
    Last Post: 09-02-2010, 08:05 AM
  4. Changing SC Oil.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-03-2010, 11:58 PM
  5. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
