Thread: Startup a/f ratio
Results 1 to 8 of 8
  1. #1 Startup a/f ratio
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    Question here guys. What tables and how do I adjust a/f ratio on a cold start. My tuning has led me to perfect ltft. But as a result cold starts run richer and richer until.it misses a little bit.
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  2. #2 Re: Startup a/f ratio
    Not really sure, but thats kinda how any car is. The cooler the temp, the more fuel it will use at start up to help increase the temp of the motor quicker.
  3. #3 Re: Startup a/f ratio
    Arizona
    Take out some fuel then start with 5%,from 80-130 degrees ect as an example.since colder air is denser and your on 65 lb injectors that seems like a logical step
  4. #4 Re: Startup a/f ratio
    Feb 2009
    flintnasty MI
    You dont have alot of details but I would assume your injector constant is not setup for e85 and you made alot of changes to the maf table.
    I would switch back to a stock maf table and fix your injector constant.
  5. #5 Re: Startup a/f ratio
    Jun 2010
    Beloit, WI
    parkave from what table exactly the "initial vs startup ect cold start" table?
    and dark im lost by what u mean on injector constant. do you mean the injector flow rate table? its been awhile but i believe that table had the correct flow rate for the 60# injectors then -30% across the board. right now the car believes it has between 42# to 44# injectors. it starts fine then progressivly richens itself for a minute or two and kinda chokes a little bit if u try to leave before it starts leaning back out.
    --00 Red GTP--
    13.07@108mph
  6. #6 Re: Startup a/f ratio
    Feb 2009
    flintnasty MI
    What is it using to go rich? Commanded afr or ltft?
  7. #7 Re: Startup a/f ratio
    Jun 2010
    Beloit, WI
    I highly doubt ltft but I also haven't scanned it yet on a cold start I'll do that later today.
  8. #8 Re: Startup a/f ratio
    Arizona
    Quote Originally Posted by shawnschuldt View Post
    Yea the initial vs startup vs ect...the decay tables might also play a role in your issue.
  1. Bad startup when cold....
    By sco77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2013, 07:23 AM
  2. Zach's TGP T67 startup
    By xpzeed in forum Members Rides
    Last Post: 02-24-2013, 01:11 AM
  3. Fan Startup
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 09-12-2012, 09:15 AM
  4. Bad lag on startup & accelleration
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2009, 03:07 PM
  5. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
