So the cap with the hex key for the supercharger oil is stripped. So does this mean I just can't change it??
It means you need to figure out how to get it out and replace it so you can access the oil reservoir.
Use an easy out it'll come right out.
Call your local GM Dealership (I don't figure you'll get one aftermarket)
GM# 24500661 for the plug. Retails at $8.14. Most likely they will have to order one but you want a new one.
I don't see how it got stripped in the first place, the Hex sockets are usually perfect and that plug doesn't have to be put on with a impact... just snug it on and snug it loose
Anywho, hope the number helps you get one quicker
Go to your local auto parts store and they should know what your talking about when you tell them what you need and why.
