That is what I have to work with. If this matters I have no egr or evap.
So I should put the lq4 maf table and don't touch it and then what?
How do I go about getting my trims in check? What histogram would have to made for that? Don't a lot of people modifty the maf table to get the trims in check? That is why they do this, or no?
For afr at wot which PE would I modify if not the maf like others? As seen are stock vs what its at now. Some say do it this way some say do it that way. Especially the tuner guide contradicts some.
You read made sure you smooth your maf after changes.
I would like to know how you approach this type of thing. I am not debating with you.
