How do you tune a cammed w-body then? Lots and lots of air being drawn in just for example.
How would you get my issue dialed in? If you are adding 6psi or so more than stock then there will be an adjustment needed. Like wise bigger injectors will cause trims to jump.
Is this your own little secret of the right way to things? Not willing to share?
