Put in the 60LB IFR table, and then use the wideband to tune the MAF. This is how i have done every 3800, and i get the AFR spot on
Every professional in the business uses a stock MAF table for your specific MAF sensor.
It's an interesting phenomenon that people with basically stock setups tune their MAF curves.
As long as the injector flow rate is correct there will be no need to tune the MAF.
