Thread: Injector ?
Results 1 to 7 of 7
  1. #1 Injector ?
    Buffalo
    SO what if i had a custom tune for a gen3 with stock injectors and 3.4 pulley
    I was running a 3" DP and 2.5" cat back w/Fender wall intake
    Since then I got togs and will do a gen5 swap
    Say my stock injectors lean out, will putting 42# ones in make any difference? will they pick up automaticly where the stock ones left off?
    Would it hurt to blindly install them at the time of the gen5 install
    Thanks guys
  2. #2 Re: Injector ?
    Donating Users blowfishRus6's Avatar
    g.a.
    the 42# need to be adjusted in the tune. no it will not pick off where the other ones left off.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: Injector ?
    No...you honestly can not do any of those things without a tune...and just throwing on headers and a smaller pulley isn't safe either.
  4. #4 Re: Injector ?
    Jan 1970
    Maquoketa, Iowa
    You really shouldn't be maxing out your stock injectors on a 3.4 pulley setup. If you do upgrade injectors, you would only need to scale your IFR table and if you do it correctly, it shouldn't throw the rest of the tune off.
  5. #5 Re: Injector ?
    Buffalo
    Thanks I figured as much it would need to be tuned. I talk to a guy who just put em in and it made it run pig rich. Well I guess there still for sale if anyone wants em all six flow matched and used (40k) 180 or b.o I can give you the link, since I wont be needing them
  6. #6 Re: Injector ?
    if you just swapped the injectors without tuning for them i can almost guarantee the car wouldnt even run.
  7. #7 Re: Injector ?
    Buffalo
    I gotta get HPT back Im so SOL without it
  1. Replacing Injector
    By TCO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-10-2009, 05:12 PM
  2. 42.5# injector tables for DHP PT
    By Sabrewings in forum PCM Tuning
    Last Post: 08-18-2009, 04:44 PM
  3. Injector tuning ?
    By GTP4 in forum PCM Tuning
    Last Post: 01-28-2009, 08:57 AM
  4. 99% Injector duty
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 11:13 PM
