Thread: Transmission tuning?
Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
  1. #1 Re: Transmission tuning?
    Arizona
    Quote Originally Posted by rperry435 View Post
    Yeah i put the shift tables back to stock for now... the tcc locking up until 50% throttle was a bit excessive..
    I'm doing the maf tune/calibration tonight after I record a scan following a 30+min drive out to pickup my gxp bumper. Curious see the results
    Sent using my Galaxy SIII on Tapatalk 2
    good **** remember the things you need for the scan to yield solid results fuel multipliers like pe enrichment dfco ltft etc...if you scan and then make changes you'll never get anywhere if you don't disable the required fuel multipliers
  2. #2 Re: Transmission tuning?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I believe the only thing the thread said was to disable pe while doing the scan trying for no Kr.. Save. adjust. repeat. Until all the lft are 5% and lower (at least that's what I gathered in that part) .. I've basically just been following that walk through to get the idea how it works. I've got a 3.6 mps on the way so ill know how to do it again then.
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. XP cam tuning HELP!
    By MidnightBlue in forum PCM Tuning
    Last Post: 03-07-2011, 11:59 AM
  2. VE tuning....not necessary?
    By PacerSS in forum PCM Tuning
    Last Post: 09-21-2010, 08:06 PM
  3. PCM tuning
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 03:16 PM
  4. Tuning in WI?
    By 03GTP in forum Midwest
    Last Post: 05-26-2009, 09:45 PM
