Thread: HPTuners Advice Needed
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
  1. #1 HPTuners Advice Needed
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Im considering getting HPTuners but I'm not sure if I should, I'm not the biggest computer wiz but I definitely can figure it out, I'm not looking to do to advance things with it just log data maybe edit a few things I.E. fan run on when key off, TC lock speed, delete rear O2 codes....stuff like that, should I get HPT? Is it really that hard to set up a gauge screen with RPMs, LTFTs, KR for data logging?
    I know there's lots of good reads out there but you don't really know until you have it in front of you by then it's to late
    also another big question, can I use it on more then one car? I have two and my friends could use tunes I'm not really sure how moving from car to car works, if I change computers can I just install it on a different lap top?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: HPTuners Advice Needed
    Oct 2012
    Nowhere NY
    yeah it very user friendly, and you can use it on more then one car just have a buy separate credits for each car
    Ive been medicating with burnouts and alcohol
  3. #3 Re: HPTuners Advice Needed
    Oct 2011
    Michigan
    Would I have to buy more credits if it was like two different Grand Prixs or two different camaros? Even then as long as the engines the same 3800, LS1 ect do I need separate credits?
  4. #4 Re: HPTuners Advice Needed
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Each car cost 2 credits. Vin locked if I remember correctly.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #5 Re: HPTuners Advice Needed
    Oct 2011
    Michigan
    Does anyone know what the trial version is like?
  6. #6 Re: HPTuners Advice Needed
    Nov 2012
    Madison
    Quote Originally Posted by asite57 View Post
    Take a look..http://files.hptuners.com/VCM%20Suit...e%20(Demo).msi
    stock 99 L67 .bin https://www.dropbox.com/s/gj3tl9fgoa...09372327.bin?m
  7. #7 Re: HPTuners Advice Needed
    Oct 2011
    Michigan
    I was wondering about this ^^^ I might download it to see what it's like, it's not timed is it?
  8. #8 Re: HPTuners Advice Needed
    Nov 2012
    Madison
    I added a stock 1999 L67 .bin for you to load., in post #6
    Just click the .bin file after you install HP, no its not timed...you can play with it
  9. #9 Re: HPTuners Advice Needed
    Nov 2011
    NY
    If your first inclination is that you shouldn't, maybe you shouldn't. We shouldn't be convincing you otherwise when it doesn't work out, we are the bad guys.
    Its not hard, but if you're not comfortable with playing around pc's and software, say like MS office Excel, then you might have an issue cause it's pretty much the same, but with bigger consequences. (blown engine, tranny)
    You PAY to PLAY! Period... Each PCM you want to write to, will cost credits to unlock it!
  10. #10 Re: HPTuners Advice Needed
    Oct 2011
    Michigan
    I won't blame you guys lol and no I am fine with playing around with those software programs, thank you ill check that out, if its the trial version can I tune cars/log data with it? I know that sounds stupid because its free but I'm just wondering
  11. #11 Re: HPTuners Advice Needed
    Nov 2012
    Madison
    nada......you can do whatever with the 99.bin file just can't read or write,you would need the expensive real interface
    Check it out ..not going to hurt anything
  12. #12 Re: HPTuners Advice Needed
    Oct 2011
    Michigan
    Ok cool I'm on my iPad right now so ill check it out a little later when I get home, but I can't log data just see live data on the free trial?
  13. #13 Re: HPTuners Advice Needed
    You can't see anything your car is doing.
    You need to have the real thing to do anything with your personal car.
    That demo shows you what the VCM Editor and VCM Scanner look like and pretty much all its functions. It has a few files that you can go through to figure out what is in each and how things can be changed.
  14. #14 Re: HPTuners Advice Needed
    Nov 2012
    Madison
    Live data? you mean your car? NO........but the stock99.bin would give you a sketch of what yours might look like. I got it from Mr.Boost37 prolly when he read a 99 and saved it.
  15. #15 Re: HPTuners Advice Needed
    Oct 2011
    Michigan
    Ok cool that's exactly what I wanted to know, the demo will give me a feel for it, thank you guys!
  16. #16 Re: HPTuners Advice Needed
    May 2008
    Schuyler, NE
    If all you want to change is fan settings, etc...you should just get a canned PCM from a vendor.
  17. #17 Re: HPTuners Advice Needed
    Oct 2011
    Michigan
    I want to change it often actually each season lol
  18. #18 Re: HPTuners Advice Needed
    Oct 2012
    Nowhere NY
    I would get hptuners over a vendor, you cant beat the accessibility
  19. #19 Re: HPTuners Advice Needed
    May 2008
    Schuyler, NE
    Why would you want to do that?
  20. #20 Re: HPTuners Advice Needed
    Oct 2011
    Michigan
    There a few little things I'd like to tweak often
  1. Advice needed
    By ksteb88 in forum General Tech Discussion
    Last Post: 04-08-2011, 02:40 PM
  2. CD player instal, parts needed, advice needed
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 08:53 PM
  3. Advice needed
    By psav in forum General Tech Discussion
    Last Post: 02-18-2011, 10:25 AM
  4. Advice needed
    By ksteb88 in forum Visual/Body Modifications
    Last Post: 07-29-2010, 10:04 PM
  5. Hello all! Advice needed!
    By jeremylester in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 07:13 PM
