Thread: Hp tuner noob question?
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
  1. #41 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    It was set that way from the factory i got mixed up. So if i am not in PE mode at 30% throttle i have to be missing something really badly what my eyes see. i have it set to 100 right now so dont get into PE. I was also told that the VE table does not matter for This car unless the MAF fails, is that true or does it matter?
  2. #42 Re: Hp tuner noob question?
    I wouldnt have it set to 100%.
    If you ever got on it, the fuel wouldnt be there and thats bad news for the motor, but set it to 35% and dont get on it much until you can figure this out.
    I never saw a need to VE tune these cars for what I was after, it felt like a huge waste of time to me.
    And you are pretty much correct if the MAF ever failed it would use the VE tables.
    You might be best to start all over and go from there.
  3. #43 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    I will scann adn put up the reslutes is a couple hours and we will see. Could you be chance send me your maf cal to compare to?
  4. #44 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    I read this before i left work to get me a couple scans, AEM uego - HP Tuners Bulletin Board. then redid my wideband pid. this is what i got on two different scans
    first scan-Download Zuyovy maf 6.hpt for free on uploading.com
    first tune-Download MAF 6.hpl for free on uploading.com
    second tune-Download ZUYOVY MAF 7.hpt for free on uploading.com
    second scan-Download MAF 7.hpl for free on uploading.com
    towards the end of the second scan i did reenable Pe and gave it a 80% throttle to see how it did. Will need to richen it up alittle
  5. #45 Re: Hp tuner noob question?
    Feb 2009
    flintnasty MI
    I may suggest that you not give advice on stuff you have little working knowledge of... I understand you are just trying to help but your advice is quite specific and misguided when these questions are being asked.
  6. #46 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    Ok, is the Link a problem or is it a proper way to tune the wideband?
  7. #47 Re: Hp tuner noob question?
    You don't tune the wideband.
    You're only supposed to use it as a guide when WOT tuning.
    If you had an accurate one, then it'd be a different story.
  8. #48 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    Ok, set up is the words i should have used instead. I am still trying to make sure that it is in the ballpark so i dont hurt the engine. I am new to the tuning side of stuff and i am learning as i go. I will ask lots of questions becuase there is so much info on this site.
  9. #49 Re: Hp tuner noob question?
    that last scan is looking better.
  10. #50 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    One question that i have today is when i advanced teh itming yesterday 5 degrees across teh whole table i got a rattle type noise while cruising, put back to where it was and it went away. I run 92-93 octange fuel and it is a 3 inch exhust with no cats. while a borla xr 1 muffler. The scann er does not show any knock while driving. Just me hearing it hase me concerned.
  1. noob with a question
    By skinner in forum Introductions/Noob Questions
    Last Post: 10-18-2012, 11:11 AM
  2. Noob question
    By TheWizard in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2011, 04:41 PM
  3. noob question
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 10-15-2010, 11:41 PM
  4. Noob Question
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-13-2010, 10:30 PM
  5. noob question....
    By OhsoKleaN in forum Tires & Wheels
    Last Post: 02-08-2010, 02:32 PM
