Why is your PE enable set to 100%? I wouldn't get on it much at all without that enabled.
Your MAF tune needs a lot of work looking at those LTFT's.
Your font O2 sensor is cycling quite well most of the time.
Is the WB showing ~10 even when the front O2 sensor is cycling?
If so, either the wide band is crap or the install is faulty in some way, likely the former, or your narrow is shot or not reading correctly.
One or the other.
