Thread: Hp tuner noob question?
Results 21 to 40 of 50
  1. #21 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    I could go with that but first i have a question on the wideband and hp tuners. The wideband on a DMM reads 10.6-11.2 at idle, thats going buy the voltages on the chart that came with the wideband. Its is mouned with in 2 inches of teh narrow band in the exhaust. I have smoked the exhaust and sealed it just for ****s and grins at the header clamps. If i use the AEM wide band in hp tuners it sayes i am idleing at 16.0, so i checked the voltage with the DDM and when i hook it up it jumps to 3.02 volts. Did a wideband offset and that is how i got to where i am on the wide band. I did test the hp box witha AA batery like bill at hp tuners told me to do and it reads correct. The narrow band is a new oem sensor. So if that is correct than i must not understand. I have watched it while driving and at 9.4 and down it locks the narow band and 900MV +.
  2. #22 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    No one has any thing to say. i will be doing some more scann saterday so we will see how it goes.
  3. #23 Re: Hp tuner noob question?
    Feb 2009
    flintnasty MI
    . I have been fallowing Gary's tuning guid i got from Full throttle v6
    Thats your problem. The "gary guide" is quite possibly one of the best internet trolls ever to happen... It should really become a meme someday.
    When in "VE mode" the LTFT's are not a result of what the o2 sensor reads, but a function of air temperature and other random crud.
  4. #24 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    Question is know that i am doinga MAF tune when driben at 2000 to 2500 rpm down the road the AFR goes way rich how do i get this to stop and stay at the mid 11s for cruzing?
  5. #25 Re: Hp tuner noob question?
    Feb 2009
    flintnasty MI
    what is commanded afr vs LTFT when it does this?
  6. #26 Re: Hp tuner noob question?
    Mid 11's while bumming around town?
    Da fuq, it should be still trying to stay around 14.7.
    To maf tune, create the custom pid, set PE to 100% and go log 25 minutes of driving, get as far into the gas without seeing KR and then save the data. Copy all the way to 7,000hz and paste by half into the maf table. Do that until LTFT are close to zero. Then start working on WOT fueling.
  7. #27 Re: Hp tuner noob question?
    Feb 2009
    flintnasty MI
    no that wont work
  8. #28 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    i have done this and with that said, when i get to 2000-2400, mpd reading above 73 is when it goes way rich. I watched it on the way to work today. I know to do a wot tune after but i am not that concerned with that know. i want to get it driving right under normal conditions first. That is why i am questioning how to fix this.
    After looking at the table display it is at 12.7 wheh it goes rich vrs. 14.7 at 11 AFR
  9. #29 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    Next stupid question, how do you change the commanded afr
  10. #30 Re: Hp tuner noob question?
    Zero out all the adders. Except the add vs tps.
    Set the add vs rpm to zero and same as the AFR correction in the spark table.
    Then set your commanded AFR in the baseAFR vs ETC, then set your timing to 15-16 for WOT in the high/low tables.
  11. #31 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    So do this for all the PE stuff and set the base in PE to 14.7 like it should be??
  12. #32 Re: Hp tuner noob question?
    No.
    The car is always trying to stay at 14.7 when not getting into PE.
    Set the commaned AFR to what YOU want it to be for WOT. Like 11.4 - 11.5.
    When you scroll the mouse over each box in each table it tells you what each one does. Setting it to 14.7 would blow it up. A couple of the tuning threads on here give you the bases of tuning, but arent always 100% correct.
  13. #33 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    No.
    I am not gettng it, under fuel and genral i AFR is 14.70020 and under that it shows me sart up AFr correction. Where do i go from there. I still get confused on the screens and stuff to go to.
  14. #34 Re: Hp tuner noob question?
    engine > fuel > power enrich
    You must have the hp tuners set to advanced, so it shows you everything.
  15. #35 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    thats cool it is set at 12.4 but my main question is that if it commands 12.4 it is reading 8.8 on the wideband so wha tis the right way to fix this. the narrow band is a 900mv during this.
  16. #36 Re: Hp tuner noob question?
    Look at the tables though.
    It may be commanding 12.4 but look at what its adding to that. Look at the add vs rpm, as the rpms rise its subtracting a number from 12.4 to give you a new afr commanded. Thats why I was saying you should zero out those adders and set the afr to 11.5.
  17. #37 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    Know that makes sense. so by looking at the table why would i not zero the tps table also, it is taking 2 afr at where i cruize down the highway. The table take nother away at hight tps input. i thought it would be teh other way around.
  18. #38 Re: Hp tuner noob question?
    Thats only in PE, you dont enter PE until whatever you set it to for Throttle %.
    Otherwise its still going off the regular tables for normal driving.
  19. #39 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    i was told to set the pe delay to zero. Is that making this go into the adder for tps all the time?
  20. #40 Re: Hp tuner noob question?
    No?
    I guess I dont know what you are talking about, I've never touched the delay.
  1. noob with a question
    By skinner in forum Introductions/Noob Questions
    Last Post: 10-18-2012, 11:11 AM
  2. Noob question
    By TheWizard in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2011, 04:41 PM
  3. noob question
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 10-15-2010, 11:41 PM
  4. Noob Question
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-13-2010, 10:30 PM
  5. noob question....
    By OhsoKleaN in forum Tires & Wheels
    Last Post: 02-08-2010, 02:32 PM
