Thread: Making AN hoses
Results 1 to 9 of 9
Guest Making AN hoses 08-06-2008, 01:06 AM
02BlueGT Re: Making AN hoses 08-06-2008, 02:27 AM
SyntheticShield Re: Making AN hoses 08-06-2008, 07:11 AM
Guest Re: Making AN hoses 08-06-2008, 10:23 AM
TommyGloves Re: Making AN hoses 08-11-2008, 08:52 AM
Iron Indian Re: Making AN hoses 08-10-2008, 02:19 AM
GTX Re: Making AN hoses 01-14-2009, 11:54 PM
GPBoy00 Re: Making AN hoses 03-17-2009, 10:49 PM
Guest Re: Making AN hoses 03-17-2009, 10:56 PM
  1. #1 Making AN hoses
    TDCRacing
    Guest
    Finally getting around to doing this. This writeup will show you the proper way to make AN hose. Wether it is for fuel line, transmission line or whatever. It all has the same concept. Enjoy!
    Today we will be using -6 AN Braided hose and demonstrating how to asemble an AN hose. The fittings we will be using are a -6 AN hose fitting. And the fitting on the regulator side is a 3/8 NPT to -6 AN. First off we need something to cut Braided/rubber hose. I perfer a dremel equiped with a heavy duty cutoff wheel as shown below.This provides a nice clean cut wich is important for this process to work smoothly.
    If your looking at the end of an AN hose there are only three parts. The hose. And the 2 fittings that make up the actual AN fitting. The 2 fittings are shown below.
    Ready to get this thing going? Me too!
    First you will need to cut the hose to the needed length. Make sure you cut straight so the hose will seat properly in the fitting (will go more in depth later). Also after you finish the cut make sure there is no debris in or around the hose. Rubber shavings ect. The cut itself does not have to be absoultly perfect. You will naturally have a little fraying of the braid on the hose. You just don't want a lot because it will prevent you from inserting the hose into the fitting. The final product should look similar to this picture as shown below.
    Next we will be putting the first fitting on the hose. The first fitting looks like this.As you can see if you look inside the fitting it actually has threads. This is to help aid the insertion of the ruber hose. When rubber hose is present you can basicly just screw this fitting on. As you can imagine the threads probably don't grip braided hose very well. So you will basicly have to push it on when working with braided hose.
    Next step is to insert the fitting onto the hose. Make sure that the hose goes all the way into the fitting.Below is a simulation of how far the hose will go into the fitting. This is why it is important that you have to have a straight cut.Not perfect just no 45* angles lol. You want the hose to seat properly against the fitting.
    Insert fitting on the hose. It will not just slip on so be patient. It is a tight fit. This is why I also stress that it is important to have a minimal amount a ''fray''. If you have a lot, forget about the hose going into this fitting. You may as well re-cut and start over.
    Next is the second fitting. This actually screws through the first fitting and threads itself into the rubber hose to make a leak free seal while the first fitting is there to prevent the hose from expanding.You will need wrenches to do this. One to hold the first fitting and one to screw in the second. The proper tool would be to use AN wrenches but they are expensive.Make sure you tighten the second fitting all the way down.Assemble as shown below.
    Last well use this example for demenstration of how to connect the male AN fitting to the Female hose fitting. This is comming from a fuel regulator for a carburated engine (my mustang).
    Done. Professional leak free hose. Excuse the beat up hoses and fittings as they were laying around on the ground outside and are for example only. I'll tell you this. I leaned on my own and have never had a hose leak yet. Like I said in one of the other posts around here. If you can screw a nut and bolt together you can asemble an AN hose.
  2. #2 Re: Making AN hoses
    Hoffman/Schaumburg, IL
    Wrap the hose with masking tape before cutting, no fraying at all
  3. #3 Re: Making AN hoses
    Oklahoma
    Excellent write up. Now we need to get you a Photography and focus 101 course
    Just giving ya a hard time.
  4. #4 Re: Making AN hoses
    TDCRacing
    Guest
    I know Scotty. Can't seem to get the pictures perfect. And yes masking tape does work quite well.
  5. #5 Re: Making AN hoses
    Donating Users
    Palatine, IL
    Quote Originally Posted by TDCRacing View Post
    Use the Macro focus function on your camera. It should look like like a flower icon.
    Nice write up!
  6. #6 Re: Making AN hoses
    Moore, Oklahoma
    Using masking tape on the line before making the cut with a cut off wheel prevents most if not all frying, it worked for me anyway when I did my fuel lines. Also I used a little grease where that second fitting goes into the first to help it slide in easier.
    Good write up and pictures, this was hard to come by when I was doing mine. Someone (I forget who) hooked me up with this link that helped out a lot. I pretty much went by this.
    Aeroquip Stainless Braided Hose and Fittings Assembly Information
    Good luck...
    Shawn W. Larsen
  7. #7 Re: Making AN hoses
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    very imformative and instructional for the beginner! nice work
    COMP G
  8. #8 Re: Making AN hoses
    SE Level Member GPBoy00's Avatar
    Minnesota
    Now, what someone needs to do is get a write-up for what you need to do AN fittings and braided lines for under the hood fuel lines.
    2000 Pontiac Grand Prix GTP Daytona 500 Pace Car Replica.
  9. #9 Re: Making AN hoses
    TDCRacing
    Guest
    They have one, It's in this section too.
  1. Making Jerky for the first time
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 04-02-2012, 10:56 AM
  2. making a cheap cold air intake ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 04:10 PM
  3. Making a cheap cold air intake [*]
    By nvsridez in forum How To Write-Ups/Tech Tips
    Last Post: 11-05-2009, 10:10 PM
  4. Making a bigger cubby hole in center console [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 02-28-2009, 11:11 PM
  5. Brakes making noise.
    By TDCRacing in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2008, 10:03 AM
