Thread: PE nuts
Results 21 to 40 of 68
Threaded View
  1. #1 PE nuts
    Barksdale AFB, LA
    I've got my trims down pretty good. Actually kinda happy about that. Cells 2 and 4 are right where they should be, which is good for my trip I'm going on next week. What has me concerned is PE mode.
    For some reason, its totally FUBAR'd. I thought it was my tune being off, and that maybe my PE was a little off, but PE just sucks. With my VE tuning file, I have PE set to enable at 100% TPS so its pretty much disabled. I got only a flash here and there of a half a degree of knock all the way up to 55% TPS.
    Once I got done tuning, I set PE back to enable at 30% and as soon as PE enables I get like 6-10* of knock and it stays.
    My O2s when that happened were around 920-ish I think (wasn't recording at first). I stopped, looked at the Base_PE_AF table and my AFR at the time this was happeneing was in the low 11s... Probably way too damn rich. So, I put the AFR to 13 for all the areas I would need it and went again. Same thing, except now my O2s are around 898. Too lean, I guess.
    The car ran great without PE, but I can't get it right. Where should my O2s be? And anything else I can be adjusting? As it is right now, PE is way off.
    Remember, I have a L36, not an L67. Attached are my PE tables...
    PE nuts Attached Files
    2009 Subaru Impreza WRX STI
  1. rustang lug nuts question
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 04:01 AM
  2. Where do these nuts belong?
    By DRWBRTq19 in forum General Tech Discussion
    Last Post: 06-16-2008, 11:22 PM
  3. I truly am totally nuts.
    By Ron Vogel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2008, 04:09 AM
