Thread: Where do these nuts belong?
Results 1 to 13 of 13
  1. #1 Where do these nuts belong?
    SE Level Member DRWBRTq19's Avatar
    Jefferson City MO
    I've had my inner door panel off for awhile (read years), now I've fixed my slow window motor and I'm ready to put everything back together. But I found these:
    I've had a few good suggestions from my local peeps, but I just wanna see if anyone might have a definite answer of where they came from.
    I don't remember removing them from anything, and nothing appears to be loose. They were just lying in the bottom of the door.
    If you think you know please chime in.
    DRew
  2. #2 Re: Where do these nuts belong?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Remove other side maybe to check for sure?
  3. #3 Re: Where do these nuts belong?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Those look the nuts for when you remove your rear seat. There are 2 studs with a u on the bottom part of the back seat
    PS. 10mm?
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: Where do these nuts belong?
    Oklahoma
    There's a loose nut in the car!!
    Okay, well it sounded funny.
  5. #5 Re: Where do these nuts belong?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Possibly from the mirror mount?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  6. #6 Re: Where do these nuts belong?
    GT Level Member BabyBlue's Avatar
    Odessa, MO
    Man there is a lot of mounting being talked about in this thread.
  7. #7 Re: Where do these nuts belong?
    New Salem, ND
    Quote Originally Posted by BabyBlue View Post
    Lastnight at work I learned that in Texas if a sheep is stuck in the fence it is mountain time, otherwise it is central time.
  8. #8 Re: Where do these nuts belong?
    May 2008
    McHenry IL
    haha nice andrew anyways yeah i took my rear seat out to put my kenwoods in the upper deck and those look like the 10 millys that hold the seat in place and the seat belts.
  9. #9 Re: Where do these nuts belong?
    Odessa, MO
    Well considering you said you were working on your window motor and they were inside your door panel, I say they look a lot like the nuts that hold the window regulator to the door. Sometimes new regulators have a couple already on them so the regulator will "hang" until can get them all started which leaves you with a couple extras. Double check though, but that's my guess.
  10. #10 Re: Where do these nuts belong?
    Jefferson City MO
    The case is solved thanks to you meddling kids and that darn dog! More specifically Andrew_99GTP, who I must apologize too for so quickly dismissing his idea (even if not done public, I still feel bad). My mirror has always been quite solid so I thought that there was no way that the nuts came from it.
    However, while sitting in my car today I decided to go ahead and peal back the foam in front of the mirror mount nuts, and look what I found:
    IMPOSTERS! It looks like I am not the 1st to have this door panel off after all.
    Thanks to all who chimed in some ideas, its you who make forums like this one informative and so great.
    Drew
  11. #11 Re: Where do these nuts belong?
    New Salem, ND
    What do I win .
    On a side not it looks like your mirror was bent all to **** at one time, probably even broke off. The reason I say this is because the paint is pealing off like the metal was bent at one time.
  12. #12 Re: Where do these nuts belong?
    Jefferson City MO
    Quote Originally Posted by Andrew_99GTP View Post
    What do I win .
    Yup I noticed that as well. I was thinking about how I need to go in there and cover that bear metal up.
    After I bought the car I started noticing little things that indicate being in an accident (misaligned rear bumper, missing emblem on trunk, etc). The more I find, the more I wonder how bad it was, or how many accidents it was (BTW carfax reports nothing, just consider that).
    Thanks again Andrew.
    Drew
  13. #13 Re: Where do these nuts belong?
    New Salem, ND
    going through the same thing with my pickup. I am positive it was in a passenger side accident.
    Glad I could help.
  1. rustang lug nuts question
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 04:01 AM
  2. I truly am totally nuts.
    By Ron Vogel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2008, 04:09 AM
