Quote Originally Posted by Sabrewings View Post
I did all that by the full write with my stock file. Well, except the TM part. Why would adding TM make this go away?
I think we're on to something with the KR being spark reduction from a TM setting.
Your not increasing the TM just increasing the numbers under the TM tables wich if set to there max (higest numbers) will disable the TM. Brian was trying to say raise the numbers not the TM. makes sense? What this will do is prevent TM from being applied wich will prevent timing from being pulled wich will prevent the kr from happening,
You have more mods than stock. So you would want to raise the TM setting even higher than stock because you will cross that threshold being you make more power than stock. Even with a stock setup TM is still being applied. Were just trying to exclude TM from possibly being the cause of your kr. Thats why were disabling it for now.
