Thread: PE nuts
Results 1 to 20 of 68
  1. #1 Re: PE nuts
    you should never ever max your injectors with your amount of mods. is it possible that one of your injectors is fubar'd or your fuel rail/line is kinked in any way?
    i didnt really look, but how does your timing look? are you commanding something like 30* WOT?
  2. #2 Re: PE nuts
    Barksdale AFB, LA
    I don't believe I have a fueling issue. I have no misfires recorded, and as the PCM commands a particular AFR the O2 sensor is showing its achieving that AFR. I'm just wondering why I need such high O2s to not knock.
    I'm going to do some maintenance at home. I'm about to order PRJ wires, AL605 plugs, and a new O2 sensor. If that doesn't fix it, I'll do a fuel pressure test. Depending on the results from that, it might be time for new injectors (since I was planning on swapping to 04-05 L67 or maybe L32 injectors anyway before I start moving towards more mods so I always have the headroom).
    2009 Subaru Impreza WRX STI
  1. rustang lug nuts question
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 04:01 AM
  2. Where do these nuts belong?
    By DRWBRTq19 in forum General Tech Discussion
    Last Post: 06-16-2008, 11:22 PM
  3. I truly am totally nuts.
    By Ron Vogel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2008, 04:09 AM
