Thread: Order to tune tables in?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Order to tune tables in?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by 01gpgt01 View Post
    What Throttle body so you have? if you have a GT throttle body then your maf table is fine, If you have A gtp TB then your running about 10 percent lean if your on a GT Maf table
    I have a GT throttle body on my car. I also have a L67 throttle body laying around. People have told me it's better to use the L67 one, but maybe I'll just stick with what I have.
  2. #22 Re: Order to tune tables in?
    its better to use the L67 because there'd be less turbulance in the air going in.
  3. #23 Re: Order to tune tables in?
    Okay thanks man. And someone on here could provide me with those tables?
  4. #24 Re: Order to tune tables in?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Bedwards View Post
    I can when you get your tuner. you can also find them on HPTuners .com in the repository
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #25 Re: Order to tune tables in?
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by Pure2sin View Post
    Wouldn't he be able to use the L32 MAP and not have to rewire the connector? That is what I am doing at least.
    If you're talking about the differences between the GT and GTP MAP sensors, then no, you can't use the GT one, because it actually goes into the UIM of L26/L36, and snaps in. It's completely different in how it reads to, since it's not really designed to read much into boost.
  6. #26 Re: Order to tune tables in?
    Minnesota
    Hmmm Monte Carlos must be different. Because right now I can run either a L32 or L36 MAP on my car. The connector is the same between my L36 and L32 MAP and the Vac line just goes to the vac T on the LIM.
  1. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  2. about to order HID's...
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-09-2010, 09:49 PM
  3. 42.5# injector tables for DHP PT
    By Sabrewings in forum PCM Tuning
    Last Post: 08-18-2009, 04:44 PM
  4. LT1 Maf tables
    By FoSHO99 in forum General Tech Discussion
    Last Post: 04-21-2009, 01:11 PM
