Thread: Order to tune tables in?
Results 1 to 20 of 26
  1. #1 Order to tune tables in?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. Is there a specific order in which to tune the different tables? I'm new to tuning, and I'm not sure if certain ones should be configured before other ones (fuel tuning, MAF tuning etc.). I'm just trying to gather as much information as possible. Thanks guys.
  2. #2 Re: Order to tune tables in?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    to many variables. But you would have to baseline where your at. But in general you tune Maf/fueling first then spark
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Order to tune tables in?
  4. #4 Re: Order to tune tables in?
    Hagerstown,Md
    Matt beat me to it.Thats a good general start. Do yourself a huge favor and skip the VE tune part. Its worthless
  5. #5 Re: Order to tune tables in?
    car reads from the maf all the time making the VE useless right?
  6. #6 Re: Order to tune tables in?
    Charles City, IA
    Yup unless the maf fails then it goes into ve mode. Relying on map vs rpm.
    SMGPFC Two Nipple General
  7. #7 Re: Order to tune tables in?
    Hagerstown,Md
    Only time the car refers to the actual VE table is if one of two things happen. The Mafs unplugged or the maf fails
  8. #8 Re: Order to tune tables in?
    Awesome.
    So in otherwords its nice for it to be close to right so you can drive without a MAF in case of failure but having it spot on is a waste of time?
  9. #9 Re: Order to tune tables in?
    This is for the DHP Power Tuner. Will it be similar for HP Tuners?
  10. #10 Re: Order to tune tables in?
    Hagerstown,Md
    Yes
  11. #11 Re: Order to tune tables in?
    Okay, thank you. I also have a question regarding the instructions to get a good scan:
    It says:
    The secret to getting a good scan is a very slow progression from low MAP kPa values up to 110 MAP kPa or so.
    Since I have an L36 MAP, will it read properly?
  12. #12 Re: Order to tune tables in?
    Nope.
    I'd suggest getting an L67 MAP.
    $5 at a local wrecker with the connector.
    Or I could mail you one lol.
  13. #13 Re: Order to tune tables in?
    Nope.
    Hmmm. So if I changed to a L67 MAP, L67 throttle body and L67 MAF, would it be really difficult to change the tune? Like I said, I am just starting to try learn all this. It is so new to me. Lol.
  14. #14 Re: Order to tune tables in?
    Bastard Reptile's Avatar
    Kansas City, MO
    Does the SSM90 kit not come with L67 MAP sensor? either way, when you change map sensors, you need to use the L67 MAP table in the PCM. The MAF table is also going to need to be calibrated to a GTP file. That'll be a start, then you go from there.
  15. #15 Re: Order to tune tables in?
    Quote Originally Posted by Reptile View Post
    No it doesn't come with an L67 MAP or an L67 MAF. Are there pre-made tables I can use for the L67 MAF and MAP sensors when I do decide to change them.
  16. #16 Re: Order to tune tables in?
    Minnesota
    Wouldn't he be able to use the L32 MAP and not have to rewire the connector? That is what I am doing at least.
  17. #17 Re: Order to tune tables in?
    You can use the MAP table from an L67 bin seeing as they are never changed.
    Also use the L67 MAF table then begin to tune from there.
  18. #18 Re: Order to tune tables in?
    Hagerstown,Md
    Quote Originally Posted by Bedwards View Post
    The GTP and GT mafs are exactly the same. The tables themselves are very different however. If your running a l36 Throttle body theres no need to make any changes to the table other then normal skewing. if your on a GTP Throttle body you need to get a GTP maf table and go from there. Hope this makes sense.
  19. #19 Re: Order to tune tables in?
    Quote Originally Posted by 01gpgt01 View Post
    Oh okay. I guess what I'm asking is if anyone could provide me with a L67 MAF/MAP table when I finally decide to try tuning. Or would it even be worth changing the MAF table, since it's already tuned for the L36 one.
  20. #20 Re: Order to tune tables in?
    Hagerstown,Md
    What Throttle body so you have? if you have a GT throttle body then your maf table is fine, If you have A gtp TB then your running about 10 percent lean if your on a GT Maf table
  1. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  2. about to order HID's...
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-09-2010, 09:49 PM
  3. 42.5# injector tables for DHP PT
    By Sabrewings in forum PCM Tuning
    Last Post: 08-18-2009, 04:44 PM
  4. LT1 Maf tables
    By FoSHO99 in forum General Tech Discussion
    Last Post: 04-21-2009, 01:11 PM
