Thread: DHP help 04 GTP
Results 21 to 40 of 57
  1. #1 Re: DHP help 04 GTP
    GXP Level Member
    Mar 2015
    Tomball
    I don't know if it works that way with 04+. My car would drop below the 9's in AFR and no matter what I did in the MAF it would still dip really low. I finally set the PE AFR and it hasn't dropped that low. I went and set everything back and the AFR dropped below the 9's again so I set it back the PE AFR (12's) to what I had it when it wasn't so rich and it's holding. I don't know what's different but there are some things that don't work on 04+ cars for some people. Like injector Skew. It didn't do anything, but Industrial Fish says it worked fine in his car. I had to adjust the IFR to get my car to run correctly, and so did Chrism1.
    Jeff
  2. #2 Re: DHP help 04 GTP
    I don't have DHP so I couldn't say why some things may seem different.
    I never had a issue setting the AFR to 11.5 and then disable all adder tables. Add vs RPM vs Time table I zero out.
  3. #3 Re: DHP help 04 GTP
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Like Jeff said. 04+ ones are a little funky. Injector skew was always a hassle for me, runs a million times better once i adjusted ifr. On basically a stock table for my maf with my IFR adjusted it was almost perfect.
    But a buddy's car who I helped tune took to the injector skew like a fish to water. Why? it was a 97.
    As far as your AFR, without a wideband you don't know what it really is. So just set it to what you want it at and then get a wideband.
    If you're on 93, set it somewhere around 11.5-11.8. IF you're on E85, go lower like 11.0 or even 10.7, 10.8 range. I have my PE set to 10.8, Most WOT runs I end up in the 11.0, to 11.1 range. Close enough for me.
    Also, if it goes to a 10 something afr and you're getting knock then there is another issue. With that much fuel you should drown any KR out. Check your timing, and TCC lockup settings.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Re: DHP help 04 GTP
    export your dhp scan as a csv file, and email it to me. i cant really read that file you linked. but from what i see your lean. and you never went wot in the scan.
  5. #5 Re: DHP help 04 GTP
    Jan 2014
    United States
    I also need to fix when PE gets used, I am hitting boost sometimes without PE being enabled.
    Sorry, that was an excel file with formatting to highlight any events I rendered important. I just dropped in the csv version into the folder Scotty. I went to 100%TP At rows 866 and 1108, (3:19:917 & 4:14:177)
    Also chrs, I need to do some reading on how TCC lockup settings affect knock. I didn't know that was even a factor. And I have read in a few forum posts that running too rich will cause knock, especially if you're in the low 10's.
    Sent from my SM-G935T using Tapatalk
  6. #6 Re: DHP help 04 GTP
    unless you have a wb hooked up there the a/f reading means nothing on your scan. its not actual.
    pe enable is a folder in PE, its likely set to 40% throttle then it enters pe. other then know when it enables, your scans not showing it it either.
  7. #7 Re: DHP help 04 GTP
    Jan 2014
    United States
    That's not entirely true though, because the PE table changes the Commanded AFR when it is enabled. I was under the impression that the PCM would use that commanded AFR to calculate how much enrichment to provide given PE mode is enabled. Am I wrong in saying that?
    Another note on over richening the mixture possibly causing knock:
    If you have a given air boost level, and you pump a lot of extra gas into the already hot cylinder, wouldn't the cylinder compression pressure spike possibly too high, thus causing knock? That's a point that someone made on the forums somewhere else.
  8. #8 Re: DHP help 04 GTP
    you wont see it entering pe on the scan tho. you only know its in pe mode when you know your tp% it enables.
    if you dont have a wb installed, your a/f scan means nothing really, thats all commanded and not actual.
    if you tune via the ltft, thats the best your gonna do at this point woth out a wideband.
    dont adjust your injectors, they are stock. you can only tune the maf at this point to control the trims and a/f.
    and id put the pe rpm vs time folder back to the file you snagged from the db bin.
  9. #9 Re: DHP help 04 GTP
    Jan 2014
    United States
    Hey guys,
    Im 99% sure I bricked my PCM. It froze up at 86% on a flash and then the car rebooted like it was finished, but DHP said that there was a connection error. Then no start. Nothings easy for me these days lol. I'm about to run to the junkyard and grab a PCM but I need to know if there will be any issues ahead of time. I'm sure this answer is somewhere, but can I just grab any 04+ grand prix PCM?
  10. #10 Re: DHP help 04 GTP
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    06+ were wonky, probably won't work with DHP.
    04-05 are the only ones you can really use, and while you're there grab the stuff to make an off board. Obd2 plug from inside the car and the PCM plug, blue one on the left IIRC. Just grab them all to be safe.
    Then a +12vDC power supply from almost anywhere and build yourself an off board. Stop bricking PCMs lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  11. #11 Re: DHP help 04 GTP
    Oct 2018
    Colorado
    Have instructions on how to make that off board? I wired it up the same way it showed in a post here by explicit-spade but when I go to try and read it with HPtunner it says Vehicle power not detected. I have it connected to a +12v /1.5 amp power supply.
  12. #12 Re: DHP help 04 GTP
    Jan 2014
    United States
    Lol thanks man. I will definitely be making an offboard today too
  13. #13 Re: DHP help 04 GTP
    if you have a cold air intake the pcm is in the open and easy to get to. you could run two alligator clips for the power to the off board and clip them to your battery for power.
    the key to not bricking the pcm is to never turn the key off if it failed for any reason. leave the key to on, and try to load another known good bin file. never turn the key off unless DHP says programming complete.
    if you had a lit cel, that can also make it act up. always clear codes if any are active. then flash or read.
  14. #14 Re: DHP help 04 GTP
    Jan 2014
    United States
    I saw that DH knows how to unbrick a PCM apparently. Is there a method to the madness? I see many people ask the same question but there's usually never a clear answer. Also, I have tried to make an offboard but it doesn't seem to communicate with the PCM properly.
    I set it up according to the following diagram, minus the CAN connections.
    Also, I may have gotten an incompatible PCM from the yard. It was from an NA 05 GP. I was able to read it but not write.
  15. #15 Re: DHP help 04 GTP
    the obd2 port also needs the wires moved around, they are numbered on the back side of the plug of most.
  16. #16 Re: DHP help 04 GTP
    http://www.grandprixforums.net/threa...ness-99-and-04 this thread has the how to i followed, i listed what one i used from the list in the thread, its been tested good on a 04 gp pcm. read and wrote to it no problem.
    na-sc pcm dont matter, as long as its a 04/05 pcm you should be ok.
  17. #17 Re: DHP help 04 GTP
    Omaha, NE
    04+ Offboard harness:
    You only need the blue connector and it's pin 7 for the ground.
    Blue PCM connector
    Blue connector 7 = ground
    Blue connector 20 = 12V Unswitched
    Blue connector 18 = 12V switched
    Blue connector 19 = 12V switched
    Blue connector 1 = CAN+ (if you want to support CAN flash)
    Blue connector 2 = CAN -
    Blue connector 15 = VPW Serial Data
    OBD II Connector
    OBD II Connector 4&5 = Ground
    OBD II Connector 16 = 12V unswitched
    OBD II Connector 6 = CAN +
    OBD II Connector 14 = CAN -
    OBD II Connector 2 = VPW Serial Data
  18. #18 Re: DHP help 04 GTP
    Jan 2014
    United States
    Yeah then mine is wired up correctly. I just plugged the new PCM into the car and now it doesn't even read. I guess it's back to the junkyard then
  19. #19 Re: DHP help 04 GTP
    i did unplug the battery on the 04 first, took only the blue plug off, then used the off board.
  20. #20 Re: DHP help 04 GTP
    Quincy, Mass
    I thought i bricked my impala's pcm. Swapped to my spare for a week then put the "bricked" one back in and it worked no problem. It was weird.
    No more GP 04 Impala SS Indy:
