Thread: DHP help 04 GTP
Results 1 to 20 of 57
  1. #1 Re: DHP help 04 GTP
    Quote Originally Posted by nickolaughagus View Post
    Update:
    I reflashed PCM and the fans work fine now. I am running an Overkill Bin off of the Repository, and I am starting a VE tune.
    I just learned that I do not have the VE table anywhere. Can anyone help me figure out why my version of Powrtuners is missing data/PIDs?
    Am I just missing information?
    i sure hope you made sure you you checked what dont belong in your tune, like the timing maf and shift points from the over kill tune. none of them are stock.
    and your mod list would likely like the stock wot timing lowered maybe 2 degrees.
  2. #2 Re: DHP help 04 GTP
    Jan 2014
    United States
    I did run the overkill tune wearily around the block; I felt so much more power than stock, it was amazing. But while watching the knock sensor, I saw some blips during WOT. I then reduced the timing several degrees where the overkill tune differed from stock, and tried it again. It's better now, but I need to properly tune out all of the knock.
    The shift points aren't that much different from stock, and they seem fine to me.
    Also I left the MAF tables as overkill had them. They are 10% lower than stock. My car runs too rich anyway so I thought it couldn't hurt.
    Sent from my SM-G935T using Tapatalk
