Thread: Serious KR at part throttle only
Results 21 to 22 of 22
Threaded View
  1. #1 Serious KR at part throttle only
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Morning everyone. Here's the scoop:
    2002 GTP Sedan
    New build mods include:
    3" C-less DP
    P-LOG
    180 T-stat
    Ported outlet/inlet Gen3
    Ported Stage 2 ZZP Throttle Body
    ZZP 9" open cone intake
    1.8 Yella Terra Roller Rockers
    New stock heat range plugs
    3.3 Modular Pulley
    60# Deka injectors
    I just got the top end put back together and have been doing some tuning and scanning with HP-Tuners.. My issue:
    Under part throttle ONLY, I get HUGE KR spikes.. this mainly happens when cruising in 4th gear and then gradually getting on the throttle. See snapshot of log screen below. Note that it does not happen when I really get on the throttle from a dig or off the line, etc. I have been up to 90%+ throttle on side streets from a standstill boosting up to 10 psi thus far with minimal to no KR (less than 1* or so).
    I have currently set PE mode to come in around 32% throttle across the board. As you can see above, I am not even in boost yet and am seeing 5* of KR at 24% throttle....
    Anyone know what I am should be doing next? Should I make PE come in even sooner to try and add fuel where I am seeing this KR? (PE mode at 20% TPS sounds crazy to me.. but not positive)
    is the 3.3" pulley too much for my current mods?? (if it is, I will do E85 on my next tank )
    let the thoughts/suggestions start flowing please!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  1. High kr at part throttle after going wot
    By DoubleBlown in forum PCM Tuning
    Last Post: 12-19-2012, 06:54 PM
  2. Hesitation at part throttle
    By 99FormulaM6r in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 08:27 PM
  3. vid shot of my car going part throttle boost
    By fst in forum Track Sessions and Kills
    Last Post: 09-08-2011, 10:51 AM
  4. Misses and KR at part throttle, oh and low compression on six
    By matt5112 in forum General Tech Discussion
    Last Post: 09-15-2010, 12:43 PM
  5. part throttle kr
    By Sabrewings in forum PCM Tuning
    Last Post: 06-09-2008, 09:30 PM
