Quote Originally Posted by ScottyDoggs View Post
who really reads lol i suck.
could be a fuel pump issue, on the fuel rail is a shrader valve, take the cap off and after it stalls see if gas sprays out when you push the pin inside.
if nothing comes out, or its flows out weak, the pump is bad.
Thanks Guys for the tips! However if it was the fuel pump issue, would I be able to straight wire fuel pump & run it for DAYS with no running issue ? Really only thing I am doing by stright wiring is bypassing the Security & Relay right ? so wouldnt that mean pump should be fine right ?
