Thread: checking out the forum for quite some time....figured I'd join.
Results 1 to 7 of 7
  1. #1 checking out the forum for quite some time....figured I'd join.
    Nov 2015
    moro
    My first question....Am I the only GP owner that has no idea where to get the replacement thin black trim/edging the sits atop the interior door panels of the '97-'03 models. Any help would be appreciated...I can't seem to find it anywhere.
  2. #2 Re: checking out the forum for quite some time....figured I'd join.
    Mar 2014
    Tucson
    Welcome to the forum!
    I've looked for that trim as well. No luck...
  3. #3 Re: checking out the forum for quite some time....figured I'd join.
    Jan 2014
    AR
    I don't think you'll find new replacement pieces, those were probably serviced as part of the trim panel assembly. I have thought of slitting some black nylon fuel injection hose and gluing or taping that on. It would look similar and probably last longer.
  4. #4 Re: checking out the forum for quite some time....figured I'd join.
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Go to a junkyard and grab your trims off a GP there. They are only held in with staples. Take your time so you don't break or crack them. Got 1 trim piece for like $2. When you reinstall them, use like hot glue or something. Mine stayed in without any adhesive.
  5. #5 Re: checking out the forum for quite some time....figured I'd join.
    Nov 2015
    New Jersey
    Welcome to the boards.
  6. #6 Re: checking out the forum for quite some time....figured I'd join.
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Welcome aboard
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  7. #7 Re: checking out the forum for quite some time....figured I'd join.
    Nov 2011
    NY
    Welcome to the Board!
    Finding parts on a 97-03 in 2015 is getting harder and harder. I don't believe that trim was ever available as a separate part and was only a part of the entire door panel. Anyways, as mentioned, either JY, or from parts car, or be inventive.
    Good Luck!
  1. Aftermarket Stereo Install? (First Time Grand Prix Owner/ First Time Forum User)
    By Kickflip Supreme in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2015, 08:58 PM
  2. Just Bought A 01 Grand Prix GTP Might as well Join a forum
    By TheMadTitian in forum Introductions/Noob Questions
    Last Post: 12-18-2012, 06:40 PM
  3. First time on a forum =D
    By gtpjosh22 in forum Introductions/Noob Questions
    Last Post: 09-04-2011, 03:28 PM
  4. Figured I'd add this forum to the pile I have already....
    By AWeb80 in forum Introductions/Noob Questions
    Last Post: 05-18-2011, 10:31 PM
  5. New Guy checking in ....former 4 time GTP owner
    By ur2noz in forum Introductions/Noob Questions
    Last Post: 05-03-2011, 06:27 PM
