thanks Scottydoggs ,but this is what I did change out! I can hear the fuel pump run for the 5-10 seconds whiles hte car is running, then sounds like the fuel pump cuts off (which is what the security is supposed to do right ? ) and like i stated in my earlier post ... I can straight wire the fuel pump and it'll run as long I want it to! So I don't think it's a fuel pump issue.
not that it matters but....History of the car... it had the dreaded fire from Valve cover leak (so it was running at one time) ... and a buddy if mine replaced wiring harness and computer and since then it's not ran without straight wiring the fuel pump (then it'll run like a raped ape!!) and it will not pass inspections b\c it wont throw a code, so I'm thinking it's all related but it may not be??
