Thread: 99 GT won't run URGENT
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #1 Re: 99 GT won't run URGENT
    SE Level Member 1FastGP's Avatar
    May 2015
    Indian Trail, NC
    Yeah I was taking a look at that earlier and I'm pretty sure it's the rear valve cover just leaking down but the shop used the cheapest gaskets they could find so somehow it does not surprise me.
    Sent from my SM-G900V using Tapatalk
  2. #2 Re: 99 GT won't run URGENT
    Feb 2013
    37.295091, -121.930053
    thats what you get for having someone else do the job that you an easily do
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    Yeah that's what I get for being lazy I guess, I'll probably just take a loss and change them myself soon, but for right now I should probably try to get it running before this weekend because I'll be busy installing an HV3 on my 02 and won't have time to mess with this one.
  4. #4 Re: 99 GT won't run URGENT
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by 1FastGP View Post
    Front gasket isn't too hard. It's getting the dog bone mount off that's the trickiest part. The rear cover is a bit more involved. You need to remove the alternator and the tensioner assembly. And some brackets that run over the cover. You don't have to completely remove the TA, just wiggle it off enough so the valve cover can slip out. Use Fel-Pro gaskets. I didn't change my grommets, but if yours are bad, replace them. Torque for the VC bolts is 89in lb.
  5. #5 Re: 99 GT won't run URGENT
    Apr 2015
    Oh, and when you pull the tensioner assemy, good time to upgrade to aluminum coolant elbows if not already done.
  6. #6 Re: 99 GT won't run URGENT
    theres no need to take the alt bracket off to do a rear valve cover. loosen the 3 bolts, and thats it.
  7. #7 Re: 99 GT won't run URGENT
    You can sneak the valve cover past w/o needing to fully pull the alt bracket as Scott says.
    Also.. big thing here.. were the grommets on the valve cover bolts replaced at the same time? If not.. your issue isn't the gasket, it's the grommet....which is all that puts pressure on the gasket to seal it.
  8. #8 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    I'm not sure I mean I wouldn't think so seeing as how these guys beat the oil filter cover off my dad's corolla with a sledge hammer because they didn't know to undo the little clip :|
  9. #9 Re: 99 GT won't run URGENT
    You didn't mention that you bring your car to the worst hack wanna be wrench turners on the planet.
    And we didn't mention that all the parts could have been had for right around $100, then half or so day of your time would have saved you $500 bucks.
    We'd rather be your friend and tell you the most common mistakes people make when working on these cars.
  10. #10 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    My dad's car has not been back there and I have no choice in where my grandma, who owns the 99 this post is about, takes her cars. But I do all the work to my 2002 myself mostly using this forum. Ya'll literally have an answer for anything grand prix
  11. #11 Re: 99 GT won't run URGENT
    Actually.. it's more 3800 based overall.
    I started out on Bonnevilles.
  12. #12 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    Yeah I thought about that after I typed that. I would probably drive anything long as it was 3800 powered.
  13. #13 Re: 99 GT won't run URGENT
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    If he doesn't already have aluminum elbows, might as well pull the whole thing out.
  14. #14 Re: 99 GT won't run URGENT
    Quote Originally Posted by SubwayGirl View Post
    You haven't read my thoughts on the long term effects of aluminum elbows yet. Off you go.. go find it.. get up to speed.
  15. #15 Re: 99 GT won't run URGENT
    May 2015
    Indian Trail, NC
    It's got aluminum elbows already on it
  16. #16 Re: 99 GT won't run URGENT
    Apr 2015
    Then just loosen the tensioner assembly. If all goes according to plan, you should be able to just slide the cover out.
  17. #17 Re: 99 GT won't run URGENT
    once again,,,why fix whats not broken? i ran plastic 2 times, it only leaked once and it was the cast elbow that leaked on my 98, ( why i changed em in the first place)
    i did install a metal one, but only to be in the cool kid club cause it got a engine swap. 2 inches of chrome, wooo hooooooo! lol
  18. #18 Re: 99 GT won't run URGENT
    Apr 2015
    I had mine changed so it didn't have to be done again. My LIM gasket wasn't leaking coolant, I replaced it for preventative maintenance and to learn how to work on my car.
  19. #19 Re: 99 GT won't run URGENT
    see most of the time its just the O rings that leak. once in a blue moon they blow one apart.
    metal one has what sealing it? yup a O ring, what does a stock cast elbow on a 97-98 use to seal it, yup a O ring. o rings leak end of story.
    why you dont fix it till its broken.
  1. URGENT What is this?!
    By PioneerGTP in forum General Tech Discussion
    Last Post: 10-09-2012, 04:49 PM
  2. Need Urgent Help
    By ahl395 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-18-2012, 11:50 PM
  3. urgent need help misfire
    By gtcoup in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2011, 06:32 PM
  4. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
