Thread: how does a supercharger work???
Results 1 to 12 of 12
  1. #1 how does a supercharger work???
    Jan 2015
    illinois
    if i put on a smaller super charger pulley on my car would it get mpg.if i dont get into the pedal .just trying to get the idea how a supercharger works.?can i put a 3.5 pulley on a 99 gtp if
  2. #2 Re: how does a supercharger work???
    not likely. and whats the point if your not gonna get into the gas from time to time?
  3. #3 Re: how does a supercharger work???
    Witchcraft is the answer.
  4. #4 Re: how does a supercharger work???
    and a little voodoo.
  5. #5 Re: how does a supercharger work???
    Kemmerer, Wyoming
    putting a smaller pulley on the supercharger wont make it get better gas mileage. leaving the stock size pulley on will keep the supercharger spinning at its most efficient range.
  6. #6 Re: how does a supercharger work???
    Quote Originally Posted by SgtMarshal View Post
    no big stock pulley will just spin it slower thus less heat being generated by the supercharger. however smaller pulley does change the effeciency of the supercharger yes.
  7. #7 Re: how does a supercharger work???
    And to be serious here, the supercharged is "vented" or "not working" when you are just cruising on the freeway.
    It doesnt matter how fast the pulley is spinning, the BBV still works the same. It just bleeds everything off untill you are past 0in/hgs on the MAP.
  8. #8 Re: how does a supercharger work???
    Buffalo
    Yep. It just recirculates until the valve closes
  9. #9 Re: how does a supercharger work???
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    A supercharger works by forcing more air into the engine. There are two screw-type objects in the supercharger housing that are rotated by a pulley, just like a water pump or A/C compressor. The screws spin quicker as the engine RPM's increase, compressing the air going into the engine. Since this air is compressed more than normal, more air is allowed into the engine, resulting in more power.
  10. #10 Re: how does a supercharger work???
    SE Level Member Brenzilla01's Avatar
    May 2015
    Detroit, MI
    Quote Originally Posted by 01Grand PrixGT View Post
    But also means more fuel is being forced in.
  11. #11 Re: how does a supercharger work???
    fuel is injected right into the heads/cylinder. we dont have a carb on top of the blower.
  12. #12 Re: how does a supercharger work???
    Topeka, KS
    Google is a Wonderful site for answering all of your questions.
    Sent from my QTAQZ3 using Tapatalk
  1. Will this supercharger work on my 03 GTP?
    By Kilroy in forum General Tech Discussion
    Last Post: 07-25-2013, 02:36 PM
  2. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  3. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
  4. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  5. the stock supercharger belt will work on a 3.4 setup right?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2010, 11:36 AM
