Thread: replace driver power seat without any power?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #1 Re: replace driver power seat without any power?
    bring the whole drill tell him its for taking bolts off and screws. pocket the jumper wires.
    they dont allow jump boxes because they dont want you trying to turn over a engine.
  2. #2 replace driver power seat without any power?
    Oct 2013
    I understand why, but wish that rule was clearly posted somewhere. Say....I don't know.....on their website, or on a sign at the entrance or something. The guy was still an A-hole regardless.
    Oh well. At least I have a shiny new harbor freight power supply/ jumper. I'm sure I'll get plenty of use out of it anyway. Pretty badass for the price. Has got a work light, 2 dc cigarette plugs, a USB power port. Almost got the bigger one that came with all of that, plus a built in 300psi air compressor and power inverter but thought it was a bit too heavy to be lugging around a junkyard.
  3. #3 Re: replace driver power seat without any power?
    http://www.gtpworld.net/viewtopic.php?f=34&t=3636 this should have all the info.
  4. #4 Re: replace driver power seat without any power?
    Take your cordless drill in. Find the drive shaft under the seat.. unhook it.. use drill to run it forward.
    Or man up and to a 1/8 turn at a time on both bolts.. as the bolts go up.. lift the seat slightly. Sucks..but works.
  5. #5 Re: replace driver power seat without any power?
    Oct 2013
    yeah, I actually found the procedure to do that, but forum won't let me upload the pdf. something about it's size exceeding my quota.
    anyway, no matter if I try to hotwire it or manually move it, either way I'll need the drill.
  6. #6 Re: replace driver power seat without any power?
    Not if you man up and just use a wrench like I have tons of times
  1. Replies: 1
    Last Post: 10-02-2013, 07:52 PM
  2. problems with driver's power seat
    By genmo in forum General Tech Discussion
    Last Post: 07-12-2010, 10:37 PM
  3. HELP!! how do you power up power seat?
    By nemesis in forum General Tech Discussion
    Last Post: 04-14-2010, 11:56 PM
  4. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
