Thread: replace driver power seat without any power?
Results 1 to 20 of 26
  1. #1 replace driver power seat without any power?
    Oct 2013
    So I am replacing all my 07 GT cloth stock seats with good condition leather ones I found in a junkyard. The problem is there's no power or battery so I can't put the power driver seat forward to get to the bolts. Any suggestions how to get the seat pushed up without power? or how to remove it without pushing the seat forward?
  2. #2 Re: replace driver power seat without any power?
    Sep 2011
    Southern Alberta, Canada
    Quote Originally Posted by sergeantdeep View Post
    Put jumper cables on.
  3. #3 Re: replace driver power seat without any power?
    ive heard of people using a 12 volt cordless drill battery and some jumper wires. its nice and light to carry into a yard.
  4. #4 Re: replace driver power seat without any power?
    Oct 2013
    With what? You can't drive another car into the junkyard and there are no batteries in any of the cars. They takers all out and drain all fluids before putting them in yard.
  5. #5 Re: replace driver power seat without any power?
    Oct 2013
    Thanks Scotty. That makes sense actually. I'll try with a portable power supply/jumper.
  6. #6 Re: replace driver power seat without any power?
    that will work too, but it weighs as much as a battery sometimes
  7. #7 Re: replace driver power seat without any power?
    Oct 2013
    No I got a small but powerful one. I guess I just need to find a wiring diagram to figure out which wires are power, fwd, reverse, etc.
  8. #8 Re: replace driver power seat without any power?
    Sep 2011
    jump the actual battery cables.
    most power seats work without the ignition on.
  9. #9 replace driver power seat without any power?
    Oct 2013
    Can't do that. Didn't I mention this is in a junkyard? There are no battery cables, most of the wires are either cut or missing in the engine and console, no fuse box etc. Gonna have to hack directly into the seat.
  10. #10 Re: replace driver power seat without any power?
    just poke around in the plug while holding the forward button on the seat. that other thread has a link, it should tell you what wire does what tho.
  11. #11 Re: replace driver power seat without any power?
    Jan 2014
    AR
    I did this recently, using a "jump box" and a small metal pick tool. No diagram required, guess I got lucky.
  12. #12 Re: replace driver power seat without any power?
    Oct 2013
    seats-driver-power-seat-circuit-1-of-1.pdf I found the actual wiring diagram. thought I would upload it to help anyone else that might need it. Think I might install some dynamat under the carpet now that I got all the seats out.
  13. #13 replace driver power seat without any power?
    Oct 2013
    Now that I got all that figured out. Maybe you guys can help me with this. The wiring harness for my 07 is different than the seat harness on the 05. Not sure what to do here other than maybe ripping the one out of the 05 and splicing it in.
    Here's pictured of me holding the connector coming from my car, and the connector on the seat, see the size difference? I'm thinking they added some extra sensors or something for my year.
  14. #14 Re: replace driver power seat without any power?
    your supposed to take the car side plugs form the car you got the seat from., cut yours off and re splice it in.
  15. #15 Re: replace driver power seat without any power?
    Oct 2013
    That's what I figured, thanks for all your quick responses Scotty. Really helps a lot. Noobie mistake. That's why this post is in the Noobie is section. Lol. Thanks again.
  16. #16 Re: replace driver power seat without any power?
    do solder and shrink wrap em twist and tape sucks.
  17. #17 Re: replace driver power seat without any power?
    Oct 2013
    Yeah. I'm an electronics technician so that won't be a problem. Will get the car side plugs from the junkyard tommorrow and have that done in 5 minutes.
  18. #18 Re: replace driver power seat without any power?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Not sure if this helps you any but...
    Wiring:
    05 GP (Connector c311)
    Pin A-Battery Positive Voltage - Orange
    Pin B-Driver Heated Seat Cushion Temperature Sensor Low Reference - Yellow
    Pin C-Battery Positive Voltage - Orange
    Pin D-Driver Heated Seat Relay Control - Purple
    Pin E-Heated Seat Cushion Temperature Sensor Signal - Yellow/black stripe
    Pin F-Not Used
    Pin G-Ground - Black
    Pin H-Seat Belt Switch-Left - Black/white stripe
    Pin J-M-Not Used.
  19. #19 replace driver power seat without any power?
    Oct 2013
    Ok back to the drawing board. The junkyard wouldn't let me bring a jumper/power supply into the yard. I was like "!, then how the hell am I supposed to remove a power seat if you won't let me apply power to it?"
    The ignorant, fat, lazy, A-hole at the counter just looked at me with his lazy eye and a dumbfounded look on his face and said "I don't know, I just don't know"
    So I guess I'll try again tomorrow with the Jumpers on the cordless drill battery method. Hopefully they don't protest to me bringing a cordless drill in. And hopefully my drill battery is powerful enough.
  20. #20 Re: replace driver power seat without any power?
    bring the whole drill tell him its for taking bolts off and screws. pocket the jumper wires.
    they dont allow jump boxes because they dont want you trying to turn over a engine.
  1. Replies: 1
    Last Post: 10-02-2013, 07:52 PM
  2. problems with driver's power seat
    By genmo in forum General Tech Discussion
    Last Post: 07-12-2010, 10:37 PM
  3. HELP!! how do you power up power seat?
    By nemesis in forum General Tech Discussion
    Last Post: 04-14-2010, 11:56 PM
  4. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
