Thread: if i spray down my engine bay with water do i have to be concerned?
Results 1 to 10 of 10
  1. #1 if i spray down my engine bay with water do i have to be concerned?
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    if i want to degrease it cause i have an oil leak, do i have to cover anything up. i know the alternator but what about the distributor. there also little electrical connections all over the place. those too? just wondering cause i want to in the summer time
  2. #2 Re: if i spray down my engine bay with water do i have to be concerned?
    hose away. theres no reason to directly hose the alt, but it can get wet, aka splashed....... and you dont have a distributor.
    all the plugs are weather tight. de grease, and hose it down. if you got a air compressor blow it down when done, if not drive it dry.
  3. #3 Re: if i spray down my engine bay with water do i have to be concerned?
    I've never covered anything, except my air filter when cleaning my engine bay out.
  4. #4 Re: if i spray down my engine bay with water do i have to be concerned?
    Nov 2014
    winston salem,nc
    i wash mine once every 3 months because something is always breaking and want as little grease as possible when working on it, never have had a problem with doing it
  5. #5 Re: if i spray down my engine bay with water do i have to be concerned?
    dont forget to spray down under the engine first, and as much of the trans as you can. car ramps are nice to have for this.
  6. #6 Re: if i spray down my engine bay with water do i have to be concerned?
    Dec 2014
    Bensalem
    Try to stay away from the coil packs and don't use a pressure washer. You can wrap the alternator in a plastic bag so it stays dry, and avoid the intake or just cover it.
  7. #7 Re: if i spray down my engine bay with water do i have to be concerned?
    Nov 2011
    Omaha, NE
    I only use a pressure washer when I do mine, I work in a detail shop so I have access to an air compressor and other tools to get it nice and dry though
  8. #8 Re: if i spray down my engine bay with water do i have to be concerned?
    everything has weather tight plugs, hose it all at will. lol
    pressure washer is fine, as long as your not tearing any wires up by getting to close. old cars you know. brittle wires.
  9. #9 Re: if i spray down my engine bay with water do i have to be concerned?
    If I could only count how many times I pressure washed my engine bay.
    Sent from my Galaxy Far Far Away
  10. #10 Re: if i spray down my engine bay with water do i have to be concerned?
    Mar 2014
    Tucson
    A clean engine is so much nicer to work on.
    First time I cleaned mine I was a little apprehensive, so I wrapped some of the connectors with aluminum foil. Now I just hose away.
  1. Where to spray my water/meth?
    By Ifryrice in forum 04+ Specifics
    Last Post: 12-12-2013, 01:32 PM
  2. SHOULD I BE CONCERNED Rocker Arms
    By dbextreme in forum General Tech Discussion
    Last Post: 07-18-2012, 06:23 PM
  3. water in engine??????
    By tmackster in forum General Tech Discussion
    Last Post: 01-25-2010, 03:36 PM
  4. Spray brake cleaner all under the engine?
    By Greinerts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 07:54 PM
  5. Concerned about the flood of new folks
    By AlphaBetaBase in forum Off Topic Discussion
    Last Post: 01-08-2008, 09:01 PM
